주요 콘텐츠로 건너뛰기
Asus ROG Zephyrus G14 Battery Replacement
필요한 것
  1. Asus ROG Zephyrus G14 Battery Replacement, Battery: 1 단계, 이미지 1/3 Asus ROG Zephyrus G14 Battery Replacement, Battery: 1 단계, 이미지 2/3 Asus ROG Zephyrus G14 Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Flip laptop so the back cover faces up.
    • Remove the ten (M2x9) screws.
    • Remove the three (M2x4.5) screw.
    • Loosen (M2.5x6) pop-open screw without removing screw from the cover.
    • Pop-open screw CANNOT be removed. Do NOT try and remove it with any other tool. This can damage the screw and/or back cover.
  2. Asus ROG Zephyrus G14 Battery Replacement: 2 단계, 이미지 1/3 Asus ROG Zephyrus G14 Battery Replacement: 2 단계, 이미지 2/3 Asus ROG Zephyrus G14 Battery Replacement: 2 단계, 이미지 3/3
    • Place iFixit opening tool at the pop-open screw (bottom right screw), there will be a gap there to place your tool.
    • Pry your way around the perimeter of the laptop.
    • Plastic clips holding the back cover will pop free as you pry. You will hear popping noises. This is normal.
    • During reassembly push down around the perimeter of the back cover to snap the plastic clips into place.
  3. Asus ROG Zephyrus G14 Battery Replacement: 3 단계, 이미지 1/3 Asus ROG Zephyrus G14 Battery Replacement: 3 단계, 이미지 2/3 Asus ROG Zephyrus G14 Battery Replacement: 3 단계, 이미지 3/3
    • Gently lift the back cover open and remove it.
    • Plastic clips in the center of the cover will pop free when lifting the cover. Hearing popping noises and feeling some resistance is normal.
    • During reassembly, push down at the center of the cover with your hands and the hooks will snap back into place.
  4. Asus ROG Zephyrus G14 Battery Replacement: 4 단계, 이미지 1/3 Asus ROG Zephyrus G14 Battery Replacement: 4 단계, 이미지 2/3 Asus ROG Zephyrus G14 Battery Replacement: 4 단계, 이미지 3/3
    • Use the plastic spudger to gently slide back the metal retaining clasp from the connector.
    • Place your spudger under the connector and carefully pry each side up.
    • DO NOT use any metal tool for this step. Doing so may cause sparks and a short circuit to occur damaging your laptop.
  5. Asus ROG Zephyrus G14 Battery Replacement: 5 단계, 이미지 1/3 Asus ROG Zephyrus G14 Battery Replacement: 5 단계, 이미지 2/3 Asus ROG Zephyrus G14 Battery Replacement: 5 단계, 이미지 3/3
    • Remove the four (M2x4.5) screws securing the battery.
  6. Asus ROG Zephyrus G14 Battery Replacement: 6 단계, 이미지 1/3 Asus ROG Zephyrus G14 Battery Replacement: 6 단계, 이미지 2/3 Asus ROG Zephyrus G14 Battery Replacement: 6 단계, 이미지 3/3
    • Lift the battery and remove it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Omar Henriquez
회원 가입일: 09/08/23
163 평판
안내서 1개 작성함
York University, Team 2-9, O'Regan Fall 2023 York University, Team 2-9, O'Regan Fall 2023 회원
YORK-O'REGAN-F23S2G9
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 33
7일 전: 200
30일 전: 811
전체 시간: 5,453
