주요 콘텐츠로 건너뛰기
Asus ROG Zephyrus G14 Thermal Paste Replacement
필요한 것
  1. Asus ROG Zephyrus G14 Thermal Paste Replacement, Opening the device: 1 단계, 이미지 1개 중 1개
    • Start by unscrewing the bottom case. There are two different size screws. One long one short.
    • The ones marked in red are the short ones. As for the ones in orange are the long ones.
  2. Asus ROG Zephyrus G14 Thermal Paste Replacement, Unplugging the Battery: 2 단계, 이미지 2개 중 1개 Asus ROG Zephyrus G14 Thermal Paste Replacement, Unplugging the Battery: 2 단계, 이미지 2개 중 2개
    • Using a plastic spudger push back the retaining clasp for the battery plug. It is a sliding motion so push it to the right with the battery closest to you.
  3. Asus ROG Zephyrus G14 Thermal Paste Replacement, Removing the cooler: 3 단계, 이미지 1개 중 1개
    • Marked in red and orange are the screws that hold on the cooler. They are all the same size but I would still keep track of if it was holding on a fan or a block.
    • Marked in yellow are the power and signal wires for the fans. Using a plastic spudger slowly walk the male plug out of its socket.
    • Using the same spudger's flat side pry around the two dies. The old thermal paste will fight back so take your time.
    • Carefully remove the display cable concealed with plastic on the leftmost side of the board - marked in blue.
    • Remove the wifi coax cables (black and white) concealed with plastic to the rightmost side of the board - marked in pink.
    • Only then the cooling unit can be freely removed.
  4. Asus ROG Zephyrus G14 Thermal Paste Replacement, Cleaning and appling the paste: 4 단계, 이미지 3개 중 1개 Asus ROG Zephyrus G14 Thermal Paste Replacement, Cleaning and appling the paste: 4 단계, 이미지 3개 중 2개 Asus ROG Zephyrus G14 Thermal Paste Replacement, Cleaning and appling the paste: 4 단계, 이미지 3개 중 3개
    • You can see where the thermal paste was so make sure to apply it on the same surfaces.
    • I have marked two small parts that are easy to miss.
    • I used 70% rubbing alcohol, tissues, and the flat end of a spudger to remove the old paste.
    • I used a plastic spudger to spread the paste on the chips to make sure that it will make full contact.
    • Replace the cooler by reversing the steps in step 3.
  5. Asus ROG Zephyrus G14 Thermal Paste Replacement, The bottom case: 6 단계, 이미지 1개 중 1개
    • Button up the device by placing and screwing on the bottom case.
    • The screws marked in orange are long. The ones marked in red are short.
  6. Asus ROG Zephyrus G14 Thermal Paste Replacement, Temps before: 7 단계, 이미지 2개 중 1개 Asus ROG Zephyrus G14 Thermal Paste Replacement, Temps before: 7 단계, 이미지 2개 중 2개
    • Before new paste.
  7. Asus ROG Zephyrus G14 Thermal Paste Replacement, The results: 8 단계, 이미지 3개 중 1개 Asus ROG Zephyrus G14 Thermal Paste Replacement, The results: 8 단계, 이미지 3개 중 2개 Asus ROG Zephyrus G14 Thermal Paste Replacement, The results: 8 단계, 이미지 3개 중 3개
    • After new Thermal paste.
    • For the testing, I used 3D mark time spy without the demo. As well as a custom fan curve. The profile was set to turbo for both runs.
결론
다른 14명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
jon bush
회원 가입일: 11/19/20
591 평판
안내서 1개를 작성함
댓글 9개
I used metal tweezers and my laptop won’t turn on now. What did I do?
Mason - 답글
Did you manage to get an answer to this? I didn't use metal tweezers but my laptop won't turn on and it's blinking as if it's trying to run but it can't!
OVO Architects -
Open up chips and look if there are cracks on chips, if there are, then you got a dead chip.
hazard4636 -
You have probably created a spark between the tweezers and the laptop circuit while the battery power is still on, bring it to a repair shop that provides micro soldering service and let them fix it.
Jerry Li -
I followed this and even used ifixit tools and now my laptop won't boot. No bios, no charge light, no cpu light, no fans. I followed it exactly, grounded myself, didn't touch the motherboard, didn't even get up as to not accidentally generate static, worked on concrete and a wooden table, none of the connections are loose or damaged. It just won't turn on. What happened and how can I fix it?
Daniel Carbaugh (Danny) - 답글
댓글 쓰기
조회 통계:
지난 24시간: 66
지난 7일: 351
지난 30일: 846
전체 시간: 27,996
