주요 콘텐츠로 건너뛰기
Asus Rog GL55VW-DH71 CD/DVD Drive Replacement
필요한 것
  1. Asus Rog GL55VW-DH71 CD/DVD Drive Replacement, Battery: 1 단계, 이미지 3개 중 1개 Asus Rog GL55VW-DH71 CD/DVD Drive Replacement, Battery: 1 단계, 이미지 3개 중 2개 Asus Rog GL55VW-DH71 CD/DVD Drive Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Flip the laptop over so the backside is facing upwards.
    • Using both hands, slide the lock mechanisms outwards and pull up to remove the battery.
  2. Asus Rog GL55VW-DH71 CD/DVD Drive Replacement, Keyboard: 2 단계, 이미지 3개 중 1개 Asus Rog GL55VW-DH71 CD/DVD Drive Replacement, Keyboard: 2 단계, 이미지 3개 중 2개 Asus Rog GL55VW-DH71 CD/DVD Drive Replacement, Keyboard: 2 단계, 이미지 3개 중 3개
    • Remove the nine 15.4mm Phillips #00 screws.
    • Remove the four 8.7mm Phillips #00 screws from the hard drive mounting bracket.
    • Remove the hard drive bracket.
  3. Asus Rog GL55VW-DH71 CD/DVD Drive Replacement: 3 단계, 이미지 2개 중 1개 Asus Rog GL55VW-DH71 CD/DVD Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Flip laptop over and open the screen.
    • Wedge some plastic opening tools between the keyboard and case.
    • Work your way around with the plastic opening tools until the keyboard is separate from the case.
    • Do not try to lift the keyboard straight off at this time. There are some ribbon cables that attach the motherboard to the keyboard that need to be removed first.
  4. Asus Rog GL55VW-DH71 CD/DVD Drive Replacement: 4 단계, 이미지 3개 중 1개 Asus Rog GL55VW-DH71 CD/DVD Drive Replacement: 4 단계, 이미지 3개 중 2개 Asus Rog GL55VW-DH71 CD/DVD Drive Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the ZIF connected ribbon cables for the touchpad and keyboard by gently lifting the latch on the connector point, then slide the ribbon cable out. Repeat for each cable.
    • Verify all ribbon cables are disconnected and out of the way, and lift the keyboard out of the assembly.
  5. Asus Rog GL55VW-DH71 CD/DVD Drive Replacement, CD/DVD Drive: 5 단계, 이미지 2개 중 1개 Asus Rog GL55VW-DH71 CD/DVD Drive Replacement, CD/DVD Drive: 5 단계, 이미지 2개 중 2개
    • Locate the CD/DVD drive and slide it out the side of the laptop.
결론
작성자
3다른 기여자 명과 함께
Addison Thomas
회원 가입일: 02/14/18
1,232 평판
안내서 8개를 작성함
USF Tampa, Team S1-G2, Nance Spring 2018 USF Tampa, Team S1-G2, Nance Spring 2018 회원
USFT-NANCE-S18S1G2
4 회원들
안내서 8개를 작성함
1가이드 댓글
Unnecessary complication of a simple task. Simply unscrew one screw (on the bottom of the laptop) and pull the drive out of the laptop case.
Mezamir - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 23
전체 시간: 1,696
