주요 콘텐츠로 건너뛰기
Asus TF300T Tablet Display Replacement
필요한 것
  1. Asus TF300T Tablet Display Replacement, Display: 1 단계, 이미지 2개 중 1개 Asus TF300T Tablet Display Replacement, Display: 1 단계, 이미지 2개 중 2개
    • Disconnect the dock and make sure the power is turned off.
    • Use plastic opening tool to pry screen up and remove from outer casing.
    • Be gentle with the plastic opening tool when you reach the charging port as the thinner plastic could be broken easily.
  2. Asus TF300T Tablet Display Replacement: 2 단계, 이미지 3개 중 1개 Asus TF300T Tablet Display Replacement: 2 단계, 이미지 3개 중 2개 Asus TF300T Tablet Display Replacement: 2 단계, 이미지 3개 중 3개
    • Pull up on the black circuit board protector.
    • Turn off the hard power switch before working with the tablet. Use a tool to slide the switch to the position marked "off".
    • For most of the replacement operation, you do not have to remove the battery once you turned off the switch. Make sure that you do not short anything with the metal tools.
  3. Asus TF300T Tablet Display Replacement: 3 단계, 이미지 3개 중 1개 Asus TF300T Tablet Display Replacement: 3 단계, 이미지 3개 중 2개 Asus TF300T Tablet Display Replacement: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a Phillips #00 screwdriver to remove the 3mm screws connecting the battery to the motherboard.
    • Use the same screwdriver to remove two 3mm screws connecting the clips.
    • Use tweezers to remove two wires connected from the battery to the motherboard.
    • Use the spudger to remove the battery from the case.
  4. Asus TF300T Tablet Display Replacement: 4 단계, 이미지 2개 중 1개 Asus TF300T Tablet Display Replacement: 4 단계, 이미지 2개 중 2개
    • Use a Phillips #00 Screwdriver to remove the 3mm screws that connect the metal board with the screen.
    • Use a hairdryer on high and heat the edges of the screen. Melt the adhesive holding the screen to the casing of the tablet.
    • Take out the display away from the screen.
결론
작성자
3다른 기여자 명과 함께
Khairuz Zaki Md Rujhan
회원 가입일: 05/22/17
461 평판
안내서 3개를 작성함
IUPUI, Team S2-G2, Wilson Summer 2017 IUPUI, Team S2-G2, Wilson Summer 2017 회원
IUPUI-WILSON-SU17S2G2
3 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 12
전체 시간: 1,119
