주요 콘텐츠로 건너뛰기
Asus TF300T Tablet Motherboard Replacement
필요한 것
  1. Asus TF300T Tablet Motherboard Replacement, Motherboard: 1 단계, 이미지 1/2 Asus TF300T Tablet Motherboard Replacement, Motherboard: 1 단계, 이미지 2/2
    • Disconnect the dock and make sure the power is turned of.
    • Use plastic opening tool to pry screen up and remove from outer casing.
    • Be gentle with the plastic opening tool when you reached the charging port as the thinner plastic could be broken easily.
  2. Asus TF300T Tablet Motherboard Replacement: 2 단계, 이미지 1/3 Asus TF300T Tablet Motherboard Replacement: 2 단계, 이미지 2/3 Asus TF300T Tablet Motherboard Replacement: 2 단계, 이미지 3/3
    • Pull up on the black circuit board protector.
    • Turn off the hard power switch before working with the tablet. Use a tool to slide the switch to the position marked "off".
    • For most of the replacement operation, you do not have to remove the battery once you turned off the switch. Make sure that you do not short anything with the metal tools.
  3. Asus TF300T Tablet Motherboard Replacement: 3 단계, 이미지 1/2 Asus TF300T Tablet Motherboard Replacement: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use a Phillips #00 Screwdriver to remove nine 3mm screws that is connected to the motherboard.
    • Use tweezers to remove connected part as shown in the picture.
  4. Asus TF300T Tablet Motherboard Replacement: 4 단계, 이미지 1/1
    • Remove the motherboard using the plastic opening tool gently.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Khairuz Zaki Md Rujhan
회원 가입일: 05/22/17
461 평판
안내서 3개 작성하였습니다
IUPUI, Team S2-G2, Wilson Summer 2017 IUPUI, Team S2-G2, Wilson Summer 2017 회원
IUPUI-WILSON-SU17S2G2
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 25
전체 시간: 1,475
