소개
If your device does not produce any sound, follow this guide to replace the faulty speaker.
필요한 것
Disconnect the dock and make sure the power is turned off.
Use plastic opening tool to pry screen up and remove from outer casing.
이 단계에 사용된 도구:Tweezers$4.99
Use a Phillips #00 screwdriver to remove the 3mm screws connecting the battery to the motherboard.
Use the same screwdriver to remove two 3mm screws connecting the clips.
Use tweezers to remove two wires connected from the battery to the motherboard.
Use the spudger to remove he battery from the case.
다른 한 분이 해당 안내서를 완성하였습니다.
