주요 콘텐츠로 건너뛰기
Asus TUF Gaming FX705G Fan Replacement
필요한 것
  1. Asus TUF Gaming FX705G Fan Replacement, Back Cover: 1 단계, 이미지 1/2 Asus TUF Gaming FX705G Fan Replacement, Back Cover: 1 단계, 이미지 2/2
    • Remove the eleven Phillips #0 screws that secure the back cover.
  2. Asus TUF Gaming FX705G Fan Replacement: 2 단계, 이미지 1/2 Asus TUF Gaming FX705G Fan Replacement: 2 단계, 이미지 2/2
    • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
    • You will hear pops as the back cover releases.
  3. Asus TUF Gaming FX705G Fan Replacement, Battery: 3 단계, 이미지 1/2 Asus TUF Gaming FX705G Fan Replacement, Battery: 3 단계, 이미지 2/2
    • Remove the three Phillips #00 screws from the battery housing.
  4. Asus TUF Gaming FX705G Fan Replacement: 4 단계, 이미지 1/2 Asus TUF Gaming FX705G Fan Replacement: 4 단계, 이미지 2/2
    • Disconnect the wire from the motherboard, and lift the battery from its housing.
  5. Asus TUF Gaming FX705G Fan Replacement, Fan: 5 단계, 이미지 1/2 Asus TUF Gaming FX705G Fan Replacement, Fan: 5 단계, 이미지 2/2
    • Remove the five Phillips #00 screws from the fan casings.
    • The left fan has three screws and the right fan has two screws.
  6. Asus TUF Gaming FX705G Fan Replacement: 6 단계, 이미지 1/3 Asus TUF Gaming FX705G Fan Replacement: 6 단계, 이미지 2/3 Asus TUF Gaming FX705G Fan Replacement: 6 단계, 이미지 3/3
    • Unplug the cables that connect the fan to the motherboard.
  7. Asus TUF Gaming FX705G Fan Replacement: 7 단계, 이미지 1/3 Asus TUF Gaming FX705G Fan Replacement: 7 단계, 이미지 2/3 Asus TUF Gaming FX705G Fan Replacement: 7 단계, 이미지 3/3
    • Lift the motherboard to unclip the housing clip on the back of the fan.
    • Remove the fan.
결론
다른 15명이 해당 안내서를 완성하였습니다.
Britney Smit
회원 가입일: 10/15/19
477 평판
안내서 2개 작성하였습니다
댓글 3개
A bit nerve-racking, but got the new CPU fan installed, seems to be working fine according to armory crate. I did note that the CPU fan plug was quite stiff but I did manage to carefully wiggle it out. Anyways found your instructions very helpful especially the pics.
Thank You.
1857classic - 답글
Is it possible to change the cpu an gpu I'm a noob for sure thanks
Like to change them to make it a better pc might not be able to FX705DY
Christopher Hall - 답글
This was very helpful. Thank you
Sue Olmos - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 19
30일 전: 93
전체 시간: 15,762
