소개
You may need to replace one or both fans in your Asus TUF Gaming FX705G if you experience overheating in your laptop. This can decrease efficiency and be harmful to the computer’s motherboard. During this process, be cautious of wires and make sure to avoid discharges of static electricity. This a very crucial, as discharges can cause elements of the laptop to short circuit.
필요한 것
다른 15명이 해당 안내서를 완성하였습니다.
댓글 3개
A bit nerve-racking, but got the new CPU fan installed, seems to be working fine according to armory crate. I did note that the CPU fan plug was quite stiff but I did manage to carefully wiggle it out. Anyways found your instructions very helpful especially the pics.
Thank You.
Is it possible to change the cpu an gpu I'm a noob for sure thanks
Like to change them to make it a better pc might not be able to FX705DY
