주요 콘텐츠로 건너뛰기
Asus TUF Gaming FX705G M.2 SSD Replacement
필요한 것
  1. Asus TUF Gaming FX705G M.2 SSD Replacement, Back Cover: 1 단계, 이미지 1/2 Asus TUF Gaming FX705G M.2 SSD Replacement, Back Cover: 1 단계, 이미지 2/2
    • Remove the eleven Phillips #0 screws that secure the back cover.
  2. Asus TUF Gaming FX705G M.2 SSD Replacement: 2 단계, 이미지 1/2 Asus TUF Gaming FX705G M.2 SSD Replacement: 2 단계, 이미지 2/2
    • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
    • You will hear pops as the back cover releases.
  3. Asus TUF Gaming FX705G M.2 SSD Replacement, Battery: 3 단계, 이미지 1/2 Asus TUF Gaming FX705G M.2 SSD Replacement, Battery: 3 단계, 이미지 2/2
    • Remove the three Phillips #00 screws from the battery housing.
  4. Asus TUF Gaming FX705G M.2 SSD Replacement: 4 단계, 이미지 1/2 Asus TUF Gaming FX705G M.2 SSD Replacement: 4 단계, 이미지 2/2
    • Disconnect the wire from the motherboard, and lift the battery from its housing.
  5. Asus TUF Gaming FX705G M.2 SSD Replacement, M.2 SSD: 5 단계, 이미지 1/1
    • Remove the Phillips #00 screw on the left side of the M.2 SSD.
  6. Asus TUF Gaming FX705G M.2 SSD Replacement: 6 단계, 이미지 1/1
    • Gently lift the screw side of the SSD to approximately a 45 degree angle and pull away from slot to remove it from the laptop.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Emma Despres
회원 가입일: 10/15/19
231 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 28
전체 시간: 4,015
