주요 콘텐츠로 건너뛰기
Asus TUF Gaming FX705G Speakers Replacement
필요한 것
  1. Asus TUF Gaming FX705G Speakers Replacement, Back Cover: 1 단계, 이미지 1/2 Asus TUF Gaming FX705G Speakers Replacement, Back Cover: 1 단계, 이미지 2/2
    • Remove the eleven Phillips #0 screws that secure the back cover.
  2. Asus TUF Gaming FX705G Speakers Replacement: 2 단계, 이미지 1/2 Asus TUF Gaming FX705G Speakers Replacement: 2 단계, 이미지 2/2
    • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
    • You will hear pops as the back cover releases.
  3. Asus TUF Gaming FX705G Speakers Replacement, Battery: 3 단계, 이미지 1/2 Asus TUF Gaming FX705G Speakers Replacement, Battery: 3 단계, 이미지 2/2
    • Remove the three Phillips #00 screws from the battery housing.
  4. Asus TUF Gaming FX705G Speakers Replacement: 4 단계, 이미지 1/2 Asus TUF Gaming FX705G Speakers Replacement: 4 단계, 이미지 2/2
    • Disconnect the wire from the motherboard, and lift the battery from its housing.
  5. Asus TUF Gaming FX705G Speakers Replacement, Speakers: 5 단계, 이미지 1/2 Asus TUF Gaming FX705G Speakers Replacement, Speakers: 5 단계, 이미지 2/2
    • Use your fingers to lift the speaker from the housing and follow the wire path carefully, lifting the wire out of place around the base.
  6. Asus TUF Gaming FX705G Speakers Replacement: 6 단계, 이미지 1/1
    • Repeat the removal process on the second speaker, being careful not to rip the wire.
  7. Asus TUF Gaming FX705G Speakers Replacement: 7 단계, 이미지 1/1
    • With the second speaker removed from the track, carefully disconnect the three wires from the insert on the motherboard.
결론
Alanna Campbell
회원 가입일: 10/15/19
103 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 23
전체 시간: 1,489
