주요 콘텐츠로 건너뛰기
Asus TUF Gaming FX705G Track Pad Replacement
필요한 것
  1. Asus TUF Gaming FX705G Track Pad Replacement, Back Cover: 1 단계, 이미지 1/2 Asus TUF Gaming FX705G Track Pad Replacement, Back Cover: 1 단계, 이미지 2/2
    • Remove the eleven Phillips #0 screws that secure the back cover.
  2. Asus TUF Gaming FX705G Track Pad Replacement: 2 단계, 이미지 1/2 Asus TUF Gaming FX705G Track Pad Replacement: 2 단계, 이미지 2/2
    • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
    • You will hear pops as the back cover releases.
  3. Asus TUF Gaming FX705G Track Pad Replacement, Battery: 3 단계, 이미지 1/2 Asus TUF Gaming FX705G Track Pad Replacement, Battery: 3 단계, 이미지 2/2
    • Remove the three Phillips #00 screws from the battery housing.
  4. Asus TUF Gaming FX705G Track Pad Replacement: 4 단계, 이미지 1/2 Asus TUF Gaming FX705G Track Pad Replacement: 4 단계, 이미지 2/2
    • Disconnect the wire from the motherboard, and lift the battery from its housing.
  5. Asus TUF Gaming FX705G Track Pad Replacement, Track pad: 5 단계, 이미지 1/2 Asus TUF Gaming FX705G Track Pad Replacement, Track pad: 5 단계, 이미지 2/2
    • Take the ribbon wire out of the track pad.
  6. Asus TUF Gaming FX705G Track Pad Replacement: 6 단계, 이미지 1/2 Asus TUF Gaming FX705G Track Pad Replacement: 6 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the two screws holding the track pad in place.
  7. Asus TUF Gaming FX705G Track Pad Replacement: 7 단계, 이미지 1/2 Asus TUF Gaming FX705G Track Pad Replacement: 7 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Take the ground wire ribbon and pry it off of the motherboard housing with tweezers.
  8. Asus TUF Gaming FX705G Track Pad Replacement: 8 단계, 이미지 1/3 Asus TUF Gaming FX705G Track Pad Replacement: 8 단계, 이미지 2/3 Asus TUF Gaming FX705G Track Pad Replacement: 8 단계, 이미지 3/3
    • Use the iFixit opening tool to pry the track pad up slightly at the top and pull the latch at the top to free the track pad.
    • Slide the track pad up and out of the housing unit.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Britney Smit
회원 가입일: 10/15/19
477 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 15
전체 시간: 1,847
