주요 콘텐츠로 건너뛰기
Asus Tablet MeMO Pad 7 ME7000C Battery Replacement
필요한 것
  1. Asus Tablet MeMO Pad 7 ME7000C Battery Replacement, Back Panel: 1 단계, 이미지 1/2 Asus Tablet MeMO Pad 7 ME7000C Battery Replacement, Back Panel: 1 단계, 이미지 2/2
    • Flip over the tablet so the back cover is facing you. Hold the second button on the left below the volume buttons down until it powers off.
  2. Asus Tablet MeMO Pad 7 ME7000C Battery Replacement: 2 단계, 이미지 1/3 Asus Tablet MeMO Pad 7 ME7000C Battery Replacement: 2 단계, 이미지 2/3 Asus Tablet MeMO Pad 7 ME7000C Battery Replacement: 2 단계, 이미지 3/3
    • Beginning in the upper corner of the tablet, use the blue plastic opening tool and run it along the seam. Do this slowly so you don't cause damage to the device.
    • If you are having trouble using the blue plastic opening tools, try using the black spudger instead.
  3. Asus Tablet MeMO Pad 7 ME7000C Battery Replacement: 3 단계, 이미지 1/2 Asus Tablet MeMO Pad 7 ME7000C Battery Replacement: 3 단계, 이미지 2/2
    • Pull the rear panel and the display screen away from each other.
  4. Asus Tablet MeMO Pad 7 ME7000C Battery Replacement, Battery: 4 단계, 이미지 1/3 Asus Tablet MeMO Pad 7 ME7000C Battery Replacement, Battery: 4 단계, 이미지 2/3 Asus Tablet MeMO Pad 7 ME7000C Battery Replacement, Battery: 4 단계, 이미지 3/3
    • Using the spudger, gently press on the black button on the plug port to release the battery from the plug.
  5. Asus Tablet MeMO Pad 7 ME7000C Battery Replacement: 5 단계, 이미지 1/2 Asus Tablet MeMO Pad 7 ME7000C Battery Replacement: 5 단계, 이미지 2/2
    • Remove the battery from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Katie
회원 가입일: 04/10/18
735 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 628
