소개
This guide will walk you through the steps to replace a cracked or non-working rear-facing camera lens in an Asus Tablet MeMo Pad 7 ME700C. Make sure you are using the proper tools and exercising caution while opening the back panel to avoid causing damage to the tablet. Because the rear-facing camera is located on the motherboard, be sure to follow all prerequisite guides before replacing the camera.
필요한 것
Flip over the tablet so the back cover is facing you. Hold the second button on the left below the volume buttons down until it powers off.
Using the spudger, gently press on the black button on the plug port to release the battery from the plug.
Gently unplug the microphone from the motherboard using a pair of blunt tweezers.
Using the tweezers flip the cream tab up to release the camera ribbon.
Gently lift the silver adhesive to remove the camera ribbon from motherboard.
Pull the silver tape away from camera.
