주요 콘텐츠로 건너뛰기
Asus Transformer Book T100TAF Battery Replacement
필요한 것
  1. Asus Transformer Book T100TAF Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Detach the keyboard from the screen by depressing the silver button the hinge and pulling upwards on the tablet.
  2. Asus Transformer Book T100TAF Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Take the tablet-portion of the device and carefully pry the screen open using either the plastic or metal spudger. Each interior clip needs to be released from the edges.
  3. Asus Transformer Book T100TAF Battery Replacement: 3 단계, 이미지 2개 중 1개 Asus Transformer Book T100TAF Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the plastic backing from the device and locate the battery pack.
    • Battery pack
  4. Asus Transformer Book T100TAF Battery Replacement: 4 단계, 이미지 2개 중 1개 Asus Transformer Book T100TAF Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to pry the battery up from the device. Pry from different sides of the battery to loosen and break the glue that is holding it down.
    • The battery cable will release as the battery is removed from the device.
    • Be sure to recycle your old battery.
    • Do not puncture or bend the battery.
결론
To reassemble your device, follow these instructions in reverse order. After replacement, it is advised to calibrate your new battery by fully draining the battery and then charging it, uninterrupted, to 100%.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Elizabeth
회원 가입일: 10/01/16
589 평판
안내서 3개를 작성함
USF Tampa, Team 4-3, Passmore Fall 2016 USF Tampa, Team 4-3, Passmore Fall 2016 회원
USFT-PASSMORE-F16S4G3
4 회원들
안내서 10개를 작성함
댓글 3개
Bonjour
Remplacement sans problème pour un ASUS T200TA
Par contre il a perdu le paramétrage du Boot.
Ou puis je retrouver ce parametrage??
jp.boubal - 답글
Bonjour quelqu’un sait comment retirer la batterie d’origine de l’ordinateur (au niveau de la connection)?
Merci
Pierre-Alain Gallion - 답글
Hi
What glue did you use to secure the new battery?
Thank you
Paul
Paul - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 23
지난 30일: 88
전체 시간: 16,132
