주요 콘텐츠로 건너뛰기
Asus Transformer Book T100TAF Motherboard Replacement
필요한 것
  1. Asus Transformer Book T100TAF Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Detach the screen from the keyboard using the silver button and pulling the screen in the upwards direction.
  2. Asus Transformer Book T100TAF Motherboard Replacement: 2 단계, 이미지 1/1
    • Pry the plastic backing off of the tablet using the plastic spudger, releasing all interior clips.
  3. Asus Transformer Book T100TAF Motherboard Replacement: 3 단계, 이미지 1/1
    • Unscrew all the silver screws from the motherboard
    • 3.0 mm (3) silver phillips head
  4. Asus Transformer Book T100TAF Motherboard Replacement: 4 단계, 이미지 1/2 Asus Transformer Book T100TAF Motherboard Replacement: 4 단계, 이미지 2/2
    • Unscrew all the black screws from the motherboard with a PH00 screwdriver
    • 4.5 mm (4) black phillips head
    • 4.5 mm (2) black phillips head
  5. Asus Transformer Book T100TAF Motherboard Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    $3.99
    구매
    • Detach the battery cable by steadily pulling it away from the motherboard with angled tweezers.
  6. Asus Transformer Book T100TAF Motherboard Replacement: 6 단계, 이미지 1/1
    • Gently pry the orange ribbon cable that is near the battery cable upwards with tweezers.
  7. Asus Transformer Book T100TAF Motherboard Replacement: 7 단계, 이미지 1/1
    • Remove the black strip along the top edge, releasing the two sets of connections.
    • Adhesive may hold this strip to the motherboard.
  8. Asus Transformer Book T100TAF Motherboard Replacement: 8 단계, 이미지 1/1
    • Use tweezers to detach the black and red twisted pair cable from its connection to the motherboard.
  9. Asus Transformer Book T100TAF Motherboard Replacement: 9 단계, 이미지 1/2 Asus Transformer Book T100TAF Motherboard Replacement: 9 단계, 이미지 2/2
    • Detach the two thin black wires by grabbing them with tweezers.
  10. Asus Transformer Book T100TAF Motherboard Replacement: 10 단계, 이미지 1/1
    • With tweezers, gently flip the white clip up that is holding the white ribbon cable down. Pull the base of the white ribbon cable away from the motherboard with tweezers.
  11. Asus Transformer Book T100TAF Motherboard Replacement: 11 단계, 이미지 1/1
    • Disconnect the bottom orange ribbon cable with tweezers by pulling it away from the edge of the device.
  12. Asus Transformer Book T100TAF Motherboard Replacement: 12 단계, 이미지 1/1
    • Verify that cables are no longer attached to the motherboard.
  13. Asus Transformer Book T100TAF Motherboard Replacement: 13 단계, 이미지 1/2 Asus Transformer Book T100TAF Motherboard Replacement: 13 단계, 이미지 2/2
    • Grab the motherboard with two hands, and gently lift it out of the device.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Danielle Nendza
회원 가입일: 10/03/16
209 평판
안내서 1개 작성함
USF Tampa, Team 4-3, Passmore Fall 2016 USF Tampa, Team 4-3, Passmore Fall 2016 회원
USFT-PASSMORE-F16S4G3
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 12
전체 시간: 2,851
