주요 콘텐츠로 건너뛰기
Asus Transformer Book T100TAM-C1 Back Panel Replacement
필요한 것
  1. Asus Transformer Book T100TAM-C1 Back Panel Replacement, Back Panel: 1 단계, 이미지 1/2 Asus Transformer Book T100TAM-C1 Back Panel Replacement, Back Panel: 1 단계, 이미지 2/2
    • Remove the tablet portion of the device from the keyboard by pushing the large silver button near the base of the tablet. Pull up on the tablet to remove from the keyboard.
  2. Asus Transformer Book T100TAM-C1 Back Panel Replacement: 2 단계, 이미지 1/2 Asus Transformer Book T100TAM-C1 Back Panel Replacement: 2 단계, 이미지 2/2
    • Insert the iFixit Opening Tool into the seam of the back tablet casing and gently pry upwards. With enough force the clips will release on the back tablet casing.
    • Make sure to insert the tool in the seam between the black and gray portions of the backing. If the tool is inserted between the screen and the black portion then the screen may crack.
    • Move the iFixit Opening Tool along the seam until the entire backing is removed.
    • Be careful and try not to use too much force while taking off the backing because you may damage the clips. If you damage the clips the backing will not fit properly back onto the tablet.
결론
Brody Moore
회원 가입일: 09/06/18
807 평판
안내서 7개 작성하였습니다
Ohio State, Team S1-G2, Whitney Fall 2018 Ohio State, Team S1-G2, Whitney Fall 2018 회원
OSU-WHITNEY-F18S1G2
2 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 342
