주요 콘텐츠로 건너뛰기
Asus Transformer Book T100TAR Front Camera Replacement
필요한 것
  1. Asus Transformer Book T100TAR Front Camera Replacement, Front Camera: 1 단계, 이미지 2개 중 1개 Asus Transformer Book T100TAR Front Camera Replacement, Front Camera: 1 단계, 이미지 2개 중 2개
    • Detach and separate the screen from the keyboard by pressing the silver release button at the base of the tablet.
  2. Asus Transformer Book T100TAR Front Camera Replacement: 2 단계, 이미지 1개 중 1개
    • Take the metal spudger and insert it into the seam of the rear cover casing and gently pry upwards.
    • If done correctly, you should feel the clips release.
    • Ensure that all the clips are released by sliding the spudger along the four edges of the tablet.
    • Do not force the clips to release. This will cause them to break, and if broken, the screen will become loose. Open the rear cover gently and with caution.
  3. Asus Transformer Book T100TAR Front Camera Replacement: 3 단계, 이미지 1개 중 1개
    • Take off the rear case
  4. Asus Transformer Book T100TAR Front Camera Replacement: 4 단계, 이미지 1개 중 1개
    • Unscrew two 5mm screws from the camera board using a Phillips #0 Screwdriver.
  5. Asus Transformer Book T100TAR Front Camera Replacement: 5 단계, 이미지 1개 중 1개
    • Using a plastic opening tool, lift the white tab holding the power button cable, located on the camera board and pull out the cable strip.
  6. Asus Transformer Book T100TAR Front Camera Replacement: 6 단계, 이미지 1개 중 1개
    • Also using the plastic opening tool, gently lift up and remove the large black strip connecting the camera board to the motherboard.
  7. Asus Transformer Book T100TAR Front Camera Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the camera board.
결론
작성자
1다른 기여자 명과 함께
Alyssa Ballesteros
회원 가입일: 09/07/16
683 평판
안내서 5개를 작성함
USF Tampa, Team 6-1, Remmell Fall 2016 USF Tampa, Team 6-1, Remmell Fall 2016 회원
USFT-REMMELL-F16S6G1
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 521
