주요 콘텐츠로 건너뛰기
Asus Transformer Book T100TAR Speaker Replacement
필요한 것
  1. Asus Transformer Book T100TAR Speaker Replacement, Speaker: 1 단계, 이미지 1/2 Asus Transformer Book T100TAR Speaker Replacement, Speaker: 1 단계, 이미지 2/2
    • Detach and separate the screen from the keyboard by pressing the silver release button at the base of the tablet.
  2. Asus Transformer Book T100TAR Speaker Replacement: 2 단계, 이미지 1/1
    • Take the metal spudger and insert it into the seam of the rear cover casing and gently pry upwards.
    • If done correctly, you should feel the clips release.
    • Ensure that all the clips are released by sliding the metal opening tool along the four edges of the tablet.
    • Do not force the clips to release. This will cause them to break, and if broken, the screen will become loose. Open the rear cover gently and with caution.
  3. Asus Transformer Book T100TAR Speaker Replacement: 3 단계, 이미지 1/1
    • Take off the rear case.
  4. Asus Transformer Book T100TAR Speaker Replacement: 4 단계, 이미지 1/2 Asus Transformer Book T100TAR Speaker Replacement: 4 단계, 이미지 2/2
    • Locate the left speaker, indicated by the image. They should be directly to the left of the battery.
    • Use a Phillips #0 Screwdriver to remove three 5mm screws holding the speaker in place.
  5. Asus Transformer Book T100TAR Speaker Replacement: 5 단계, 이미지 1/2 Asus Transformer Book T100TAR Speaker Replacement: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using tweezers, lift up the black tape securing the speaker connection cable.
    • Disconnect the cable from the motherboard by gently tugging on it with the tweezers.
  6. Asus Transformer Book T100TAR Speaker Replacement: 6 단계, 이미지 1/2 Asus Transformer Book T100TAR Speaker Replacement: 6 단계, 이미지 2/2
    • To remove the right speaker, begin by detaching the large black strip connecting from the camera board to the motherboard using a plastic opening tool.
  7. Asus Transformer Book T100TAR Speaker Replacement: 7 단계, 이미지 1/1
    • Using tweezers, detach the small black cable connected to the motherboard by gently tugging on it.
  8. Asus Transformer Book T100TAR Speaker Replacement: 8 단계, 이미지 1/3 Asus Transformer Book T100TAR Speaker Replacement: 8 단계, 이미지 2/3 Asus Transformer Book T100TAR Speaker Replacement: 8 단계, 이미지 3/3
    • Using tweezers, carefully remove the black tape holding the large orange strip.
    • Using a plastic opening tool, lift up the white tabs and pull the orange strip out of place.
  9. Asus Transformer Book T100TAR Speaker Replacement: 9 단계, 이미지 1/2 Asus Transformer Book T100TAR Speaker Replacement: 9 단계, 이미지 2/2
    • Disconnect the LCD connection apparatus by carefully removing the black protective strip with tweezers and gently tugging on the orange ribbon.
  10. Asus Transformer Book T100TAR Speaker Replacement: 10 단계, 이미지 1/1
    • Using the nylon spudger, very carefully disconnect the battery by gently pushing the sharper end against the base.
    • There should be a small dent in the middle; push from there.
  11. Asus Transformer Book T100TAR Speaker Replacement: 11 단계, 이미지 1/1
    • Using a Phillips #0 screwdriver, unscrew six 5mm screws holding the motherboard in place.
    • Also using a Phillips #0 screwdriver, unscrew two additional 4mm screws off the top left ends of the motherboard.
  12. Asus Transformer Book T100TAR Speaker Replacement: 12 단계, 이미지 1/2 Asus Transformer Book T100TAR Speaker Replacement: 12 단계, 이미지 2/2
    • Disconnect the speaker from the motherboard by gently tugging on the cable head with tweezers.
    • Remove the motherboard.
  13. Asus Transformer Book T100TAR Speaker Replacement: 13 단계, 이미지 1/3 Asus Transformer Book T100TAR Speaker Replacement: 13 단계, 이미지 2/3 Asus Transformer Book T100TAR Speaker Replacement: 13 단계, 이미지 3/3
    • Using a Phillips #0 screwdriver, unscrew a single 5mm screw from the bottom of the right speaker apparatus.
    • Remove the speaker.
결론
Alyssa Ballesteros
회원 가입일: 09/07/16
683 평판
안내서 5개 작성하였습니다
USF Tampa, Team 6-1, Remmell Fall 2016 USF Tampa, Team 6-1, Remmell Fall 2016 회원
USFT-REMMELL-F16S6G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 476
