주요 콘텐츠로 건너뛰기
Asus Transformer Pad Infinity Charging Port Replacement
필요한 것
  1. Asus Transformer Pad Infinity Charging Port Replacement, Charging Port: 1 단계, 이미지 2개 중 1개 Asus Transformer Pad Infinity Charging Port Replacement, Charging Port: 1 단계, 이미지 2개 중 2개
    • Take off the screen and the big motherboard.
  2. Asus Transformer Pad Infinity Charging Port Replacement: 2 단계, 이미지 3개 중 1개 Asus Transformer Pad Infinity Charging Port Replacement: 2 단계, 이미지 3개 중 2개 Asus Transformer Pad Infinity Charging Port Replacement: 2 단계, 이미지 3개 중 3개
    • Disconnect the long silver ribbon connector from the screen.
    • Remove the orange ribbon connector with the two connections.
  3. Asus Transformer Pad Infinity Charging Port Replacement: 3 단계, 이미지 1개 중 1개
    • Flip up the piece securing the ribbon to the big motherboard and remove the ribbon from the motherboard.
    • Note: This will have tape covering it, make sure not to cut the ribbon or scratch any other parts if you are looking to preserve these things.
  4. Asus Transformer Pad Infinity Charging Port Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the two screws holding the actual port, that goes to the outside of the device, in. This piece will be connected to the case.
  5. Asus Transformer Pad Infinity Charging Port Replacement: 5 단계, 이미지 1개 중 1개
    • Once removing the damaged charging port, put in your new part and reassemble the device and check if the new charging port works.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Allison Poh
회원 가입일: 10/20/15
549 평판
안내서 5개를 작성함
UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 회원
UMASSD-GULBRANDSEN-F15S5G1
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 10
전체 시간: 1,257
