이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Disconnect the long silver ribbon connector from the screen.
Remove the orange ribbon connector with the two connections.
Flip up the piece securing the ribbon to the big motherboard and remove the ribbon from the motherboard.
Note: This will have tape covering it, make sure not to cut the ribbon or scratch any other parts if you are looking to preserve these things.
Remove the two screws holding the actual port, that goes to the outside of the device, in. This piece will be connected to the case.
Once removing the damaged charging port, put in your new part and reassemble the device and check if the new charging port works.
다른 한 분이 해당 안내서를 완성하였습니다.
