주요 콘텐츠로 건너뛰기
Asus Transformer Pad Infinity LCD Display Replacement
필요한 것
  1. Asus Transformer Pad Infinity LCD Display Replacement, LCD Display: 1 단계, 이미지 3개 중 1개 Asus Transformer Pad Infinity LCD Display Replacement, LCD Display: 1 단계, 이미지 3개 중 2개 Asus Transformer Pad Infinity LCD Display Replacement, LCD Display: 1 단계, 이미지 3개 중 3개
    • Disconnect the long silver ribbon connector from the screen.
    • Remove the orange ribbon connector with the two connections.
  2. Asus Transformer Pad Infinity LCD Display Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the 4 screws around the metal portion of the screen (this is the LCD display).
  3. Asus Transformer Pad Infinity LCD Display Replacement: 3 단계, 이미지 1개 중 1개
    • Peel the orange ribbon back (it has adhesive sticking itself to the black electric tape looking stuff surrounding the metal portion).
  4. Asus Transformer Pad Infinity LCD Display Replacement: 4 단계, 이미지 1개 중 1개
    • Carefully place a preferably plastic tool between the glass portion and the electric tape looking stuff and pry off the screen from that portion.
    • Note: Take care as you’re dealing directly with with the glass and the way your touch input gets into the device.
  5. Asus Transformer Pad Infinity LCD Display Replacement: 5 단계, 이미지 1개 중 1개
    • Once removed, replace the LCD display back onto the glass screen (the new screen may or may not have new adhesive depending on where you got it.
    • If it doesn’t, make sure you secure it with the screws safely).
결론
작성자
4다른 기여자 명과 함께
Allison Poh
회원 가입일: 10/20/15
549 평판
안내서 5개를 작성함
UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 회원
UMASSD-GULBRANDSEN-F15S5G1
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 6
전체 시간: 1,230
