주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Asus Transformer Pad Infinity 수리는 자사의 서비스 설명서를 사용하세요.
  1. Asus Transformer Pad Infinity Teardown, Asus Transformer Pad Infinity Teardown: 1 단계, 이미지 1개 중 1개
    • First, turn the power off
  2. Asus Transformer Pad Infinity Teardown: 2 단계, 이미지 3개 중 1개 Asus Transformer Pad Infinity Teardown: 2 단계, 이미지 3개 중 2개 Asus Transformer Pad Infinity Teardown: 2 단계, 이미지 3개 중 3개
    • Insert a small flat head screwdriver into the 2 docking station guide ports on the bottom of the tablet.
    • Unlock screen casing tabs
    • Push tab with screwdriver to the right until it clicks
    • You should see a small arrow in the bottom of the port
    • Unlock the tabs in both docking station guide ports.
  3. Asus Transformer Pad Infinity Teardown: 3 단계, 이미지 3개 중 1개 Asus Transformer Pad Infinity Teardown: 3 단계, 이미지 3개 중 2개 Asus Transformer Pad Infinity Teardown: 3 단계, 이미지 3개 중 3개
    • Use spudger to push upward on the small plastic tabs on top of the docking station guide ports.
    • Insert the flat side of another spudger to start freeing the bottom of the screen from the case.
  4. Asus Transformer Pad Infinity Teardown: 4 단계, 이미지 3개 중 1개 Asus Transformer Pad Infinity Teardown: 4 단계, 이미지 3개 중 2개 Asus Transformer Pad Infinity Teardown: 4 단계, 이미지 3개 중 3개
    • Use your spudger to open the four plastic tabs located on either side of the tablet.
    • These tabs are very fragile.
    • Remove the screen from the body
  5. Asus Transformer Pad Infinity Teardown: 5 단계, 이미지 2개 중 1개 Asus Transformer Pad Infinity Teardown: 5 단계, 이미지 2개 중 2개
    • There is an internal power switch next to the battery connector, that will kill power to the entire device while you're working on it.
    • Don't forget to switch it back on when you're reassembling!
  6. Asus Transformer Pad Infinity Teardown: 6 단계, 이미지 3개 중 1개 Asus Transformer Pad Infinity Teardown: 6 단계, 이미지 3개 중 2개 Asus Transformer Pad Infinity Teardown: 6 단계, 이미지 3개 중 3개
    • Use your spudger to release the two digitizer ribbon cables from the mainboard.
    • Located on the left side of the tablet between the micro-HDMI and the microSD slot.
    • Use your spudger to release the LCD cable from the back of the LCD.
    • Set aside for later dissection.
  7. Asus Transformer Pad Infinity Teardown: 7 단계, 이미지 3개 중 1개 Asus Transformer Pad Infinity Teardown: 7 단계, 이미지 3개 중 2개 Asus Transformer Pad Infinity Teardown: 7 단계, 이미지 3개 중 3개
    • To remove the front facing camera (right):
    • Use your spudger to unlock the ribbon cable
    • Slide the camera out
    • To remove the rear facing camera (top):
    • Apply light lifting pressure to unplug it from it's socket
    • Remove the backup battery on the right side:
    • Unplug the cable from the motherboard with your spudger
  8. Asus Transformer Pad Infinity Teardown: 8 단계, 이미지 3개 중 1개 Asus Transformer Pad Infinity Teardown: 8 단계, 이미지 3개 중 2개 Asus Transformer Pad Infinity Teardown: 8 단계, 이미지 3개 중 3개
    • Remove the motherboard, daughterboard, and dock connector
    • Unscrew 14 points
    • Unplug the speaker from the motherboard before removing it
    • Reveal the battery connector:
    • Flip the motherboard from the top edge of the tablet down (towards the battery).
    • Unplug with light pressure from your spudger.
    • Disconnect the motherboard from the daughterboard:
    • Unlock the ribbon cable on the back side of the daughterboard
  9. Asus Transformer Pad Infinity Teardown: 9 단계, 이미지 3개 중 1개 Asus Transformer Pad Infinity Teardown: 9 단계, 이미지 3개 중 2개 Asus Transformer Pad Infinity Teardown: 9 단계, 이미지 3개 중 3개
    • Remove the battery:
    • Remove screws (eight)
    • Use your spudger underneath the battery between the 2 cells to work it free
  10. Asus Transformer Pad Infinity Teardown: 10 단계, 이미지 3개 중 1개 Asus Transformer Pad Infinity Teardown: 10 단계, 이미지 3개 중 2개 Asus Transformer Pad Infinity Teardown: 10 단계, 이미지 3개 중 3개
    • Remove the speaker:
    • Use your spudger underneath, and work it free
    • Remove the bottom screen locking mechanism:
    • Lift pieces out
  11. Asus Transformer Pad Infinity Teardown: 11 단계, 이미지 3개 중 1개 Asus Transformer Pad Infinity Teardown: 11 단계, 이미지 3개 중 2개 Asus Transformer Pad Infinity Teardown: 11 단계, 이미지 3개 중 3개
    • Now that we're left with a boring empty shell, let's return to the LCD assembly that we set aside in Step 5.
    • Remove the 4 screws. Then work your spudger underneath the edges of the LCD to separate it from the Gorilla Glass front. It has a light adhesive around all edges.
  12. Asus Transformer Pad Infinity Teardown: 12 단계, 이미지 2개 중 1개 Asus Transformer Pad Infinity Teardown: 12 단계, 이미지 2개 중 2개
    • With the LCD free, you should now be able to lay it out in a big pile of parts and the teardown is complete. Now let's see what's under all those heatsinks and tape.
  13. Asus Transformer Pad Infinity Teardown: 13 단계, 이미지 2개 중 1개 Asus Transformer Pad Infinity Teardown: 13 단계, 이미지 2개 중 2개
    • The back side of the motherboard
  14. Asus Transformer Pad Infinity Teardown: 14 단계, 이미지 3개 중 1개 Asus Transformer Pad Infinity Teardown: 14 단계, 이미지 3개 중 2개 Asus Transformer Pad Infinity Teardown: 14 단계, 이미지 3개 중 3개
    • Motherboard backside closeups
  15. Asus Transformer Pad Infinity Teardown: 15 단계, 이미지 2개 중 1개 Asus Transformer Pad Infinity Teardown: 15 단계, 이미지 2개 중 2개
    • The front side of the motherboard is where all the action is.
    • Tegra 3 quad core processor T33-P-A3
    • 2x Elpida memory J4216EBBG-GNL-F
    • Realtek? ALCS631
    • Hynix H26M64002BNR e-NAND
  16. Asus Transformer Pad Infinity Teardown: 16 단계, 이미지 3개 중 1개 Asus Transformer Pad Infinity Teardown: 16 단계, 이미지 3개 중 2개 Asus Transformer Pad Infinity Teardown: 16 단계, 이미지 3개 중 3개
    • Front side motherboard closeups
  17. Asus Transformer Pad Infinity Teardown: 17 단계, 이미지 2개 중 1개 Asus Transformer Pad Infinity Teardown: 17 단계, 이미지 2개 중 2개
    • Front and back of the daughterboard.
  18. Asus Transformer Pad Infinity Teardown: 18 단계, 이미지 2개 중 1개 Asus Transformer Pad Infinity Teardown: 18 단계, 이미지 2개 중 2개
    • The back of the LCD.
  19. Asus Transformer Pad Infinity Teardown: 19 단계, 이미지 3개 중 1개 Asus Transformer Pad Infinity Teardown: 19 단계, 이미지 3개 중 2개 Asus Transformer Pad Infinity Teardown: 19 단계, 이미지 3개 중 3개
    • Close-ups.
    • That's all I've got. I apologize for any blurry pics as all I had on hand was my cell phone ( <3 Samsung Galaxy Note.) I hope your teardowns are far less destructive than mine was. Good Luck.
    • ...and yes, it still works after reassembly. Thanks for asking.
작성자
10다른 기여자 명과 함께
Matt
회원 가입일: 08/29/12
497 평판
안내서 1개를 작성함
33가이드 댓글
Does anyone know what the internal on/off switch does on the motherboard? Right next to the battery connector. How can you see that in a tear down and not mention it?
Jcortes1982 - 답글
It is a master on/off switch. When the switch is flipped to the off position, the tablet will not operate. You can see the switch labels on the second picture of Step 13.
Matt -
Ya its for when your doing work inside the tablet your supposed to flick that off so you dont accidentally short anything. Like the on/off switch on your power supply on the back of your desktop
Jon Pileot -
Thanks for this teardown! Could the "mushy" power / volume buttons be due to poor placement of the buttons / board? Could slight nudging of the board in one direction or the other help the "mushy" buttons?
Jon Pileot - 답글
Hi there, thank you very much for this teardown. I wanted to inquire if you were able to find out anything about the gyroscopes/accelerometers/GPS and other sensors during this. I'm doing a project and this would be very helpful information.
Johnathon - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 28
지난 30일: 179
전체 시간: 101,133
