주요 콘텐츠로 건너뛰기
Asus Transformer Pad TF103C Speakers Replacement
필요한 것
  1. Asus Transformer Pad TF103C Speakers Replacement, Speakers: 1 단계, 이미지 1개 중 1개
    • Shut down your tablet before beginning the repair.
    • Insert the plastic opening tool on the side of the tablet.
    • Gently pull upwards and carefully pry open the tablet.
  2. Asus Transformer Pad TF103C Speakers Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the tool around all four sides of the tablet while gently pulling the tool up.
  3. Asus Transformer Pad TF103C Speakers Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the back cover once you have loosened it from the tablet. Set the back cover aside.
    • Rotate the tablet to match the picture.
  4. Asus Transformer Pad TF103C Speakers Replacement: 4 단계, 이미지 1개 중 1개
    • Carefully unplug the rainbow cable from the motherboard.
  5. Asus Transformer Pad TF103C Speakers Replacement: 5 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to carefully pry the battery out from the frame.
  6. Asus Transformer Pad TF103C Speakers Replacement: 6 단계, 이미지 2개 중 1개 Asus Transformer Pad TF103C Speakers Replacement: 6 단계, 이미지 2개 중 2개
    • Use the JIS #000 screwdriver to remove the four screws.
    • Keep the screws together and organized. (Label the screws, if necessary).
  7. Asus Transformer Pad TF103C Speakers Replacement: 7 단계, 이미지 1개 중 1개
    • Take the ground wire out from the top of the TF103C-L (left) speaker.
    • If you pull on the wire too much it will break off.
    • If you break the wire off you can solder it back on.
  8. Asus Transformer Pad TF103C Speakers Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the tape and unplug the wire that is connected to both of the speakers.
  9. Asus Transformer Pad TF103C Speakers Replacement: 9 단계, 이미지 2개 중 1개 Asus Transformer Pad TF103C Speakers Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the two speakers from the frame.
결론
작성자
9다른 기여자 명과 함께
Tyler Ellis
회원 가입일: 10/28/15
668 평판
안내서 4개를 작성함
UMass Dartmouth, Team 3-6, Shastany Fall 2015 UMass Dartmouth, Team 3-6, Shastany Fall 2015 회원
UMASSD-SHASTANY-F15S3G6
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 12
전체 시간: 571
