주요 콘텐츠로 건너뛰기
Asus Transformer T100 Battery Replacement
필요한 것
  1. Asus Transformer T100 Battery Replacement, Rear Cover: 1 단계, 이미지 2개 중 1개 Asus Transformer T100 Battery Replacement, Rear Cover: 1 단계, 이미지 2개 중 2개
    • Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
    • Remove the tablet by lifting up.
  2. Asus Transformer T100 Battery Replacement: 2 단계, 이미지 2개 중 1개 Asus Transformer T100 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Insert the opening tool into the seam of the tablet casing and gently pry upwards.
    • With a little force, you will feel the clips release.
  3. Asus Transformer T100 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the tool along all four edges of the tablet, making sure that all the clips are released.
    • Do not break these clips; otherwise, the screen will become less secure.
  4. Asus Transformer T100 Battery Replacement: 4 단계, 이미지 2개 중 1개 Asus Transformer T100 Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the rear casing.
  5. Asus Transformer T100 Battery Replacement, Battery: 5 단계, 이미지 1개 중 1개
    • Remove the copper tape carefully.
  6. Asus Transformer T100 Battery Replacement: 6 단계, 이미지 2개 중 1개 Asus Transformer T100 Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Gently pull back the yellow transparent plastic covering on top of the battery connection port.
  7. Asus Transformer T100 Battery Replacement: 7 단계, 이미지 3개 중 1개 Asus Transformer T100 Battery Replacement: 7 단계, 이미지 3개 중 2개 Asus Transformer T100 Battery Replacement: 7 단계, 이미지 3개 중 3개
    • Rotate the device so the top of the screen is facing you. Place the plastic opening tool underneath the battery and gently pry upwards to lift the battery out.
    • The battery wire harness will slide out as the battery is pried up.
  8. Asus Transformer T100 Battery Replacement: 8 단계, 이미지 2개 중 1개 Asus Transformer T100 Battery Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the battery by slowly peeling the battery away from the connected side.
    • The adhesive on the back will pull away from the battery.
결론
다른 69명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Taylor Pantiga
회원 가입일: 04/14/14
1,617 평판
안내서 6개를 작성함
Cal Poly, Team 13-31, Maness Spring 2014 Cal Poly, Team 13-31, Maness Spring 2014 회원
CPSU-MANESS-S14S13G31
3 회원들
안내서 6개를 작성함
22가이드 댓글
So I switched out my screen for it and its not turning on and I checked it everything was correctly place, but my Asus transformer was dead before hand so I tried charging it, and it wasn't charging, so I checked it and it seems the battery wire harness is loose enough to come off, is it possible to fix that?
christian cantu - 답글
Hi christian! How did you solve this problem? That happened to me too...
Matheus Moraes -
what is the battery part # for t100 and can you purchase it?
thank you
RJ - 답글
Part number is C12N1320. They are available from a variety of sources.
Jack Riggins - 답글
Thanks for detailed guide.
I could not get the transformer tablet to power up no matter which buttons I held for how long or in what sequence. Unplugging the battery internally and replugging fixed a hung device.
JPWhite - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 57
지난 30일: 204
전체 시간: 131,752
