주요 콘텐츠로 건너뛰기
Asus Transformer T100 Front Facing Camera Board Replacement
필요한 것
  1. Asus Transformer T100 Front Facing Camera Board Replacement, Rear Cover: 1 단계, 이미지 2개 중 1개 Asus Transformer T100 Front Facing Camera Board Replacement, Rear Cover: 1 단계, 이미지 2개 중 2개
    • Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
    • Remove the tablet by lifting up.
  2. Asus Transformer T100 Front Facing Camera Board Replacement: 2 단계, 이미지 2개 중 1개 Asus Transformer T100 Front Facing Camera Board Replacement: 2 단계, 이미지 2개 중 2개
    • Insert the opening tool into the seam of the tablet casing and gently pry upwards.
    • With a little force, you will feel the clips release.
  3. Asus Transformer T100 Front Facing Camera Board Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the tool along all four edges of the tablet, making sure that all the clips are released.
    • Do not break these clips; otherwise, the screen will become less secure.
  4. Asus Transformer T100 Front Facing Camera Board Replacement: 4 단계, 이미지 2개 중 1개 Asus Transformer T100 Front Facing Camera Board Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the rear casing.
  5. Asus Transformer T100 Front Facing Camera Board Replacement, Front Facing Camera Board: 5 단계, 이미지 1개 중 1개
    • The camera board is located in the red square in this image.
  6. Asus Transformer T100 Front Facing Camera Board Replacement: 6 단계, 이미지 2개 중 1개 Asus Transformer T100 Front Facing Camera Board Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the two screws on the camera board using a Phillips #1 Screwdriver.
  7. Asus Transformer T100 Front Facing Camera Board Replacement: 7 단계, 이미지 3개 중 1개 Asus Transformer T100 Front Facing Camera Board Replacement: 7 단계, 이미지 3개 중 2개 Asus Transformer T100 Front Facing Camera Board Replacement: 7 단계, 이미지 3개 중 3개
    • Lift up the power button cable retention clip on the motherboard and pull the cable out.
  8. Asus Transformer T100 Front Facing Camera Board Replacement: 8 단계, 이미지 2개 중 1개 Asus Transformer T100 Front Facing Camera Board Replacement: 8 단계, 이미지 2개 중 2개
    • On the camera connection apparatus, locate the silver tape that connects to the tablet.
    • Peel the silver tape off of the tablet on both sides of the connection apparatus.
    • If this step has been completed correctly, the camera board should be loose, with the tape still attached to the connection apparatus.
  9. Asus Transformer T100 Front Facing Camera Board Replacement: 9 단계, 이미지 3개 중 1개 Asus Transformer T100 Front Facing Camera Board Replacement: 9 단계, 이미지 3개 중 2개 Asus Transformer T100 Front Facing Camera Board Replacement: 9 단계, 이미지 3개 중 3개
    • Gently pull the Orange ribbon cable out of the connection port.
    • This port has no clip. The orange apparatus should slide out with a small tug.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Taylor Pantiga
회원 가입일: 04/14/14
1,617 평판
안내서 6개를 작성함
Cal Poly, Team 13-31, Maness Spring 2014 Cal Poly, Team 13-31, Maness Spring 2014 회원
CPSU-MANESS-S14S13G31
3 회원들
안내서 6개를 작성함
1가이드 댓글
Hello, can you please tell a manufacturer of the camera (is it writter somethere on it)?
Alexius Hoopakele Ae - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 32
전체 시간: 3,903
