주요 콘텐츠로 건너뛰기
Asus Transformer T100 Power Button Replacement
필요한 것
  1. Asus Transformer T100 Power Button Replacement, Rear Cover: 1 단계, 이미지 1/2 Asus Transformer T100 Power Button Replacement, Rear Cover: 1 단계, 이미지 2/2
    • Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
    • Remove the tablet by lifting up.
  2. Asus Transformer T100 Power Button Replacement: 2 단계, 이미지 1/2 Asus Transformer T100 Power Button Replacement: 2 단계, 이미지 2/2
    • Insert the opening tool into the seam of the tablet casing and gently pry upwards.
    • With a little force, you will feel the clips release.
    This image seems not to show the correct position where to place the tip of the tool initially. It suggests to pry between the frame and the glass pane from the top of the tablet. That's what I did and broke the glass - one device spoilt. Only the next picture correctly shows where to apply the tool.
    Ole Hoppe - 답글
  3. Asus Transformer T100 Power Button Replacement: 3 단계, 이미지 1/1
    • Slide the tool along all four edges of the tablet, making sure that all the clips are released.
    • Do not break these clips; otherwise, the screen will become less secure.
  4. Asus Transformer T100 Power Button Replacement: 4 단계, 이미지 1/2 Asus Transformer T100 Power Button Replacement: 4 단계, 이미지 2/2
    • Remove the rear casing.
  5. Asus Transformer T100 Power Button Replacement, Power Button: 5 단계, 이미지 1/2 Asus Transformer T100 Power Button Replacement, Power Button: 5 단계, 이미지 2/2
    • Using a flathead screwdriver, pry the button connection up.
    • There will be some resistance. Slowly increase the pressure until the button pops off.
    Good instructions and a worthy purpose to the site. Our devices should be more easily repaired. However, in my case the difficulty seems to be with the micro switch that the power button presses on. The micro switch and its circuit board look like they are replaceable. Does anyone know if repair parts are available for this device?
    Paul - 답글
결론
Use a small amount of epoxy or other adhesive to attach the new button.
다른 9명이 해당 안내서를 완성하였습니다.
Taylor Pantiga
회원 가입일: 04/14/14
1,596 평판
안내서 6개 작성하였습니다
Cal Poly, Team 13-31, Maness Spring 2014 Cal Poly, Team 13-31, Maness Spring 2014 회원
CPSU-MANESS-S14S13G31
3 회원들
안내서 6개 작성하였습니다
댓글 4개
Where can you get a button?
dsmit26 - 답글
Anyone have a link to get the button?
Seb bar -
hi
i got a major problem ....mine is tf300t and when i got the cover out the power button came out with it what should i do i can't reattach it with my bare hands plsss help me !!!!
kiko - 답글
The asus computer fell, well the screen took a beating, touch no longer works and sometimes the tablet senses as if it were touched making it difficult to perform tasks clicking etc.
The keyboard is partially working. The computer was still operation like for reading and watching to some extent
The battery ran out and found out that the power button isn't clicking really, no feedback.
Apart from the obvious problems, I'd like to first turn the tablet on after charging (have some files on it ti download). From the depiction is there a chance popping the tablet open would be of assistance? Could the screen though fall apart following opening it up? Any suggestions? Your assistance is most appreciated
Thank you
100 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 35
전체 시간: 23,264
