주요 콘텐츠로 건너뛰기
Asus Transformer T100 Rear Cover Replacement
Taylor Pantiga
Taylor Pantiga12 다른 기여자
최종 수정일 January 29, 2018
5 - 10 분
조정
더 나은 이미지가 필요함
The Asus Transformer T100 has two main hardware sections: the tablet and the base. This guide will focus on removing the plastic rear cover of the tablet.
필요한 것
도구
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
  1. Asus Transformer T100 Rear Cover Replacement, Rear Cover: 1 단계, 이미지 2개 중 1개 Asus Transformer T100 Rear Cover Replacement, Rear Cover: 1 단계, 이미지 2개 중 2개
    • Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
    • Remove the tablet by lifting up.
  2. Asus Transformer T100 Rear Cover Replacement: 2 단계, 이미지 2개 중 1개 Asus Transformer T100 Rear Cover Replacement: 2 단계, 이미지 2개 중 2개
    • Insert the opening tool into the seam of the tablet casing and gently pry upwards.
    • With a little force, you will feel the clips release.
  3. Asus Transformer T100 Rear Cover Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the tool along all four edges of the tablet, making sure that all the clips are released.
    • Do not break these clips; otherwise, the screen will become less secure.
  4. Asus Transformer T100 Rear Cover Replacement: 4 단계, 이미지 2개 중 1개 Asus Transformer T100 Rear Cover Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the rear casing.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
12다른 기여자 명과 함께
Taylor Pantiga
회원 가입일: 04/14/14
1,611 평판
안내서 6개를 작성함
Cal Poly, Team 13-31, Maness Spring 2014 Cal Poly, Team 13-31, Maness Spring 2014 회원
CPSU-MANESS-S14S13G31
3 회원들
안내서 6개를 작성함
댓글 5개
This is completely wrong. The outside case of the ASUS T100 is brushed metal.
darimini76 - 답글
there is also a white version, so actually not wrong
Jordi Vanwinkle -
Was able to remove the back cover. Needed to unplug the battery and plug it back in so the the Notebook would boot. It now boots perfectly but
when we replace the back cover it snaps in at the sides and bottom but
WILL NOT Snap in on the top (where the power switch is). All tabs on the back cover and the frame are perfect and not broken but the back cover will not snap closed completely at the top. It still powers on but the power switch sticks and have to press near the switch so it releases in the back cover cavity at the top. Anyone have any ideas on this issue. Thanks
ldajnowski - 답글
I had the same problem. Answer is not to start assemble from the top. Instead, start from the side where there is the SD slot or from the bottom end. Then everything will go. Good luck.
Bac Nguyen Ninh -
Take out your Micro Sd card first!! You will snap it in two!
Milk - 답글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 22
지난 30일: 33
전체 시간: 15,823
