주요 콘텐츠로 건너뛰기
Asus U50F-RBBAG05 Keyboard Replacement
필요한 것
  1. Asus U50F-RBBAG05 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the laptop over so the bottom is facing up.
    • Slide the two tabs on the bottom of the laptop toward the edges of laptop.
    • Slide the left tab to the left to lock it into the unlocked position. The red showing next to the tab signifies that it's unlocked.
    • You will have to hold the right tab to the right to keep the slot unlocked while removing the battery.
  2. Asus U50F-RBBAG05 Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Asus U50F-RBBAG05 Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Hold down the tab on the right side, then begin sliding the battery out.
    • Remove the old battery.
    • Next, insert the new battery into the empty slot. Release the right tab to begin locking the new battery into place. Slide the left tab to the right to completely lock the battery into the slot. The red that was showing near the left tab should be gone. This signifies that the battery is locked into place.
  3. Asus U50F-RBBAG05 Keyboard Replacement, Keyboard: 3 단계, 이미지 3개 중 1개 Asus U50F-RBBAG05 Keyboard Replacement, Keyboard: 3 단계, 이미지 3개 중 2개 Asus U50F-RBBAG05 Keyboard Replacement, Keyboard: 3 단계, 이미지 3개 중 3개
    • Insert one of the pry tools under a top corner and the other tool under the side of the same corner. Make sure to get under the metal of the keyboard, not just the first layer of plastic. Then pry the corner down and out from under the little overhang its sitting under.
    • Next, slide the pry tool on the top over to the next overhang and insert the second tool on the other side. Push down and pry out the keyboard.
    • Repeat the same process all the way down to the opposite corner.
  4. Asus U50F-RBBAG05 Keyboard Replacement: 4 단계, 이미지 2개 중 1개 Asus U50F-RBBAG05 Keyboard Replacement: 4 단계, 이미지 2개 중 2개
    • Once the keyboard is free, lift it up slightly and release the cable connection underneath.
  5. Asus U50F-RBBAG05 Keyboard Replacement: 5 단계, 이미지 2개 중 1개 Asus U50F-RBBAG05 Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Last, remove the keyboard completely from the computer.
결론
작성자
7다른 기여자 명과 함께
Kelly Greeling
회원 가입일: 02/07/17
1,044 평판
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 20
전체 시간: 501
