주요 콘텐츠로 건너뛰기
Asus U56E Laptop Screen Replacement
필요한 것
  1. Asus U56E Laptop Screen Replacement, Screen: 1 단계, 이미지 1/2 Asus U56E Laptop Screen Replacement, Screen: 1 단계, 이미지 2/2
    • Position the laptop on a flat, stable surface, with the underside facing upward.
  2. Asus U56E Laptop Screen Replacement: 2 단계, 이미지 1/3 Asus U56E Laptop Screen Replacement: 2 단계, 이미지 2/3 Asus U56E Laptop Screen Replacement: 2 단계, 이미지 3/3
    • Make sure the laptop is unplugged before removing the battery to avoid risk of electric shock.
    • Slide the two battery lock switches toward each other.
    • Lift the battery to remove it from the laptop.
  3. Asus U56E Laptop Screen Replacement: 3 단계, 이미지 1/3 Asus U56E Laptop Screen Replacement: 3 단계, 이미지 2/3 Asus U56E Laptop Screen Replacement: 3 단계, 이미지 3/3
    • Remove the 3 Phillips #00 screws holding on the back cover of the laptop.
    • Lift the cover, exposing the laptop hard drive and RAM.
  4. Asus U56E Laptop Screen Replacement: 4 단계, 이미지 1/2 Asus U56E Laptop Screen Replacement: 4 단계, 이미지 2/2
    • Remove the eight small screws holding the hard drive in.
    • The hard drive cover can now be removed by lifting the tab on the left.
  5. Asus U56E Laptop Screen Replacement: 5 단계, 이미지 1/1
    • Gently slide the hard drive left toward the edge of the laptop, then lift up to remove it.
  6. Asus U56E Laptop Screen Replacement: 6 단계, 이미지 1/2 Asus U56E Laptop Screen Replacement: 6 단계, 이미지 2/2
    • Remove the 4 Phillips #00 screws around the RAM.
  7. Asus U56E Laptop Screen Replacement: 7 단계, 이미지 1/2 Asus U56E Laptop Screen Replacement: 7 단계, 이미지 2/2
    • Remove the 10 Phillips #00 screws from the bottom of the laptop.
    • Remove 10 Phillips #000 screws from under the battery.
  8. Asus U56E Laptop Screen Replacement: 8 단계, 이미지 1/2 Asus U56E Laptop Screen Replacement: 8 단계, 이미지 2/2
    • Slide the optical drive out of the laptop.
    • Gently lift the rear plastic hinge cover to separate it from the laptop.
  9. Asus U56E Laptop Screen Replacement: 9 단계, 이미지 1/3 Asus U56E Laptop Screen Replacement: 9 단계, 이미지 2/3 Asus U56E Laptop Screen Replacement: 9 단계, 이미지 3/3
    • Remove the 3 Phillips #000 screws from each side of the hinge (six screws in total).
    • Gently lift the thin plastic cover from each side, exposing the laptop hinge.
    • Be aware of the thin cables still connected to the screen.
  10. Asus U56E Laptop Screen Replacement: 10 단계, 이미지 1/2 Asus U56E Laptop Screen Replacement: 10 단계, 이미지 2/2
    • Gently lift around the perimeter of keyboard to separate it from the laptop body.
    • It may help to use a Plastic Opening Tool.
    • Be careful not to pull too hard on the keyboard - It's connected to the motherboard with a thin ribbon cable!
  11. Asus U56E Laptop Screen Replacement: 11 단계, 이미지 1/3 Asus U56E Laptop Screen Replacement: 11 단계, 이미지 2/3 Asus U56E Laptop Screen Replacement: 11 단계, 이미지 3/3
    • Pull the display connector straight up to remove it from the motherboard.
    • Carefully detach the white and black WiFi antennas from the wireless adapter.
  12. Asus U56E Laptop Screen Replacement: 12 단계, 이미지 1/1
    • The screen can now be safely removed from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
David Zilar
회원 가입일: 09/29/15
167 평판
안내서 1개 작성함
Cal Poly, Team 14-5, Green Fall 2015 Cal Poly, Team 14-5, Green Fall 2015 회원
CPSU-GREEN-F15S14G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 15
전체 시간: 1,376
