주요 콘텐츠로 건너뛰기
Asus UL30VT-X1 Hard Drive Replacement
필요한 것
  1. Asus UL30VT-X1 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/2 Asus UL30VT-X1 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/2
    • Flip the laptop over onto the back.
  2. Asus UL30VT-X1 Hard Drive Replacement: 2 단계, 이미지 1/2 Asus UL30VT-X1 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Unscrew the three screws on the hard drive panel using a Phillips Head #00 screwdriver.
  3. Asus UL30VT-X1 Hard Drive Replacement: 3 단계, 이미지 1/2 Asus UL30VT-X1 Hard Drive Replacement: 3 단계, 이미지 2/2
    • Lift the hard drive panel up from the small cut out at the bottom with your finger to expose the hard drive.
  4. Asus UL30VT-X1 Hard Drive Replacement: 4 단계, 이미지 1/2 Asus UL30VT-X1 Hard Drive Replacement: 4 단계, 이미지 2/2
    • Grab the black pull tab with your fingers. Pull upwards and then outwards to remove the hard drive.
    • It can sometimes be a little difficult to remove the hard drive.
결론
Robert Wilcox
회원 가입일: 09/20/17
218 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 203
