주요 콘텐츠로 건너뛰기
Asus UL80J Keyboard Replacement
필요한 것
  1. Asus UL80J Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Place laptop face down with battery facing up.
  2. Asus UL80J Keyboard Replacement: 2 단계, 이미지 1/1
    • Slide unlock button to the right.
  3. Asus UL80J Keyboard Replacement: 3 단계, 이미지 1/3 Asus UL80J Keyboard Replacement: 3 단계, 이미지 2/3 Asus UL80J Keyboard Replacement: 3 단계, 이미지 3/3
    • Slide the button marked with an arrow to the left. The battery should now unclick. Slide the battery away from the laptop to remove it.
  4. Asus UL80J Keyboard Replacement, Keyboard: 4 단계, 이미지 1/1
    • Insert a plastic opening tool or a flat-head screwdriver between the laptop body and the keyboard.
  5. Asus UL80J Keyboard Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • Gently pry the keyboard up. This will allow you to unclip the keyboard.
    • Use an old plastic card or a similar flat object to prevent the keyboard from clipping back in while carefully working along the keyboard perimeter.
    • Unclipping sounds are normal.
    • Keep unclipping the keyboard along the perimeter. Once the keyboard is unclipped, be careful and do not take it out right away, as there is still a ribbon that connects the keyboard with the rest of the computer located on the bottom.
  6. Asus UL80J Keyboard Replacement: 7 단계, 이미지 1/1
    • Slowly lift the keyboard and use flash light if needed to locate the ribbon cable on the bottom. Lift the ZIF connector tab before pulling the ribbon cable out.
    • Remove the tape from the ribbon cable if needed and remove the keyboard.
결론
Kateryna Turchenko
회원 가입일: 02/20/17
201 평판
안내서 2개 작성하였습니다
USF Tampa, Team S2-G4, Lacy Spring 2017 USF Tampa, Team S2-G4, Lacy Spring 2017 회원
USFT-LACY-S17S2G4
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 10
전체 시간: 446
