주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus UL80J Motherboard Replacement
필요한 것
  1. Asus UL80J Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Place laptop face down with battery facing up.
  2. Asus UL80J Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Slide unlock button to the right.
  3. Asus UL80J Motherboard Replacement: 3 단계, 이미지 3개 중 1개 Asus UL80J Motherboard Replacement: 3 단계, 이미지 3개 중 2개 Asus UL80J Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • Slide the button marked with an arrow to the left. The battery should now unclick. Slide the battery away from the laptop to remove it.
  4. Asus UL80J Motherboard Replacement, Keyboard: 4 단계, 이미지 1개 중 1개
    • Insert a plastic opening tool or a flat-head screwdriver between the laptop body and the keyboard.
  5. Asus UL80J Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • Gently pry the keyboard up. This will allow you to unclip the keyboard.
    • Use an old plastic card or a similar flat object to prevent the keyboard from clipping back in while carefully working along the keyboard perimeter.
    • Unclipping sounds are normal.
    • Keep unclipping the keyboard along the perimeter. Once the keyboard is unclipped, be careful and do not take it out right away, as there is still a ribbon that connects the keyboard with the rest of the computer located on the bottom.
  6. Asus UL80J Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Slowly lift the keyboard and use flash light if needed to locate the ribbon cable on the bottom. Lift the ZIF connector tab before pulling the ribbon cable out.
    • Remove the tape from the ribbon cable if needed and remove the keyboard.
  7. Asus UL80J Motherboard Replacement, Motherboard: 8 단계, 이미지 1개 중 1개
    • Once the keyboard is removed, take out the nine 6 mm screws on the back side of the laptop.
  8. Asus UL80J Motherboard Replacement: 9 단계, 이미지 2개 중 1개 Asus UL80J Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the optical drive (CD drive) from the laptop.
    • Three, 3 mm screws will be underneath where the CD drive was. Remove them to be able to access the front cover.
  9. Asus UL80J Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the five, 8 mm screws from the aluminum cover underneath where the keyboard was.
    • Remove the remaining four, 5 mm screws.
    • In order to replace this you need to remove a screw that voids the warranty on your computer.
  10. Asus UL80J Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Using a plastic opening tool, gently pry open the front cover.
    • Be careful with the plastic opening tool, as you can break the cover in the thin sections.
  11. Asus UL80J Motherboard Replacement: 12 단계, 이미지 2개 중 1개 Asus UL80J Motherboard Replacement: 12 단계, 이미지 2개 중 2개
    • After you remove the front cover, the motherboard should be exposed, along with the two port boards.
    • Remove the seven, 3 mm screws holding the motherboard and ports into the frame of the laptop, as well as the two wire bundles indicated by red arrows.
    • You can now lift the motherboard out of the frame while simultaneously disconnecting the wires on the underside.
  12. Asus UL80J Motherboard Replacement: 13 단계, 이미지 3개 중 1개 Asus UL80J Motherboard Replacement: 13 단계, 이미지 3개 중 2개 Asus UL80J Motherboard Replacement: 13 단계, 이미지 3개 중 3개
    • Remove the four, 3 mm screws and disconnect the red and black wire from to the motherboard.
    • Unscrew the six, 5 mm screws to disconnect the copper heat pipe.
    • Once these are removed, the motherboard can be replaced.
결론
작성자
2다른 기여자 명과 함께
John
회원 가입일: 02/15/17
316 평판
안내서 3개를 작성함
USF Tampa, Team S2-G4, Lacy Spring 2017 USF Tampa, Team S2-G4, Lacy Spring 2017 회원
USFT-LACY-S17S2G4
3 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 21
지난 30일: 56
전체 시간: 802
