소개
If the images on your screen are distorted or if your images aren't displaying, there's a chance your screen is defective or damaged. Also if you drop your laptop or step on it, there's a chance you damaged the screen. This guide will show you how to replace your screen.
필요한 것
Flip laptop back over and open it so that the screen faces you. Several rubber cushions hide screws around the bezel (surrounding frame). Remove these first to get to the screws underneath. The two bottom covers are stickers. Then remove all screws holding the bezel in place.
There will be four 3 mm screws located on the top and two 5 mm screws located on the bottom of the bezel.
To reassemble your device, follow these instructions in reverse order. It is a good idea to check that the new screen works before reattaching the bezel.
