주요 콘텐츠로 건너뛰기
Asus UL80VT Motherboard Replacement
필요한 것
  1. Asus UL80VT Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop so you can see the back side.
  2. Asus UL80VT Motherboard Replacement: 2 단계, 이미지 1/2 Asus UL80VT Motherboard Replacement: 2 단계, 이미지 2/2
    • Identify the two slide locks below the battery. Slide them outward towards the unlock symbol. You should see a red mark that indicates that the battery is unlocked and is ready for removal.
  3. Asus UL80VT Motherboard Replacement: 3 단계, 이미지 1/1
    • Now you can remove the battery while continuing to hold the right battery lock in the unlock position.
  4. Asus UL80VT Motherboard Replacement, Hard Drive: 4 단계, 이미지 1/3 Asus UL80VT Motherboard Replacement, Hard Drive: 4 단계, 이미지 2/3 Asus UL80VT Motherboard Replacement, Hard Drive: 4 단계, 이미지 3/3
    • Flip the computer over, and unscrew the two 5 mm screws using the Phillips #0 screwdriver.
    • Lift the panel from the device.
  5. Asus UL80VT Motherboard Replacement: 5 단계, 이미지 1/2 Asus UL80VT Motherboard Replacement: 5 단계, 이미지 2/2
    • Slide the hard drive away from the SATA connector and remove the hard drive from the device.
  6. Asus UL80VT Motherboard Replacement, RAM: 6 단계, 이미지 1/1
    • Flip computer over and unscrew the two 5 mm screws using the Phillips #0 screwdriver.
  7. Asus UL80VT Motherboard Replacement: 7 단계, 이미지 1/3 Asus UL80VT Motherboard Replacement: 7 단계, 이미지 2/3 Asus UL80VT Motherboard Replacement: 7 단계, 이미지 3/3
    • Pull the clips toward the chassis of the computer. The RAM will pop up and can easily be removed.
  8. Asus UL80VT Motherboard Replacement, Keyboard: 8 단계, 이미지 1/2 Asus UL80VT Motherboard Replacement, Keyboard: 8 단계, 이미지 2/2
    • Open laptop so the keyboard is accessible.
    • Insert a plastic prying tool and push and then pull to release the keyboard from the device.
  9. Asus UL80VT Motherboard Replacement: 9 단계, 이미지 1/1
    • Lift keyboard and remove ZIF connector cables.
    • Remove the keyboard from the device.
  10. Asus UL80VT Motherboard Replacement, Motherboard: 10 단계, 이미지 1/1
    • Remove the nine 5 mm screws using the Phillips #0 screwdriver.
  11. Asus UL80VT Motherboard Replacement: 11 단계, 이미지 1/1
    • Flip the laptop over and remove nine 5 mm screws using the Phillips #0 screwdriver.
  12. Asus UL80VT Motherboard Replacement: 12 단계, 이미지 1/2 Asus UL80VT Motherboard Replacement: 12 단계, 이미지 2/2
    • Use the iFixit opening tool to remove the cd drive on the left of the laptop.
  13. Asus UL80VT Motherboard Replacement: 13 단계, 이미지 1/1
    • Use the same tool to remove the plastic top from the laptop.
  14. Asus UL80VT Motherboard Replacement: 14 단계, 이미지 1/1
    • Remove the eight 3 mm screws using the Phillips #0 screwdriver.
    • Lift up the motherboard and disconnect all wires attaching the motherboard to the rest of the computer.
  15. Asus UL80VT Motherboard Replacement: 15 단계, 이미지 1/1
    • Lift the motherboard out of the laptop and remove it from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
James DellaMorte
회원 가입일: 03/08/19
660 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S1-G5, Botvin Spring 2019 UMass Dartmouth, Team S1-G5, Botvin Spring 2019 회원
UMASSD-BOTVIN-S19S1G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 19
전체 시간: 435
