주요 콘텐츠로 건너뛰기
Asus V500CA-DB51T RAM Replacement
필요한 것
  1. Asus V500CA-DB51T RAM Replacement, Battery: 1 단계, 이미지 1/2 Asus V500CA-DB51T RAM Replacement, Battery: 1 단계, 이미지 2/2
    • The top left and right corners have .7 cm screws.
    • The two top-middle and four bottom are .4 cm screws.
    • The middle left and right are .8 cm screws.
    • Remove the screws using the Phillips #00 screwdriver.
  2. Asus V500CA-DB51T RAM Replacement: 2 단계, 이미지 1/2 Asus V500CA-DB51T RAM Replacement: 2 단계, 이미지 2/2
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. Asus V500CA-DB51T RAM Replacement: 3 단계, 이미지 1/1
    • Use the flat end of the blue plastic opening tool to lift the battery connector up out of its socket on the motherboard.
  4. Asus V500CA-DB51T RAM Replacement: 4 단계, 이미지 1/2 Asus V500CA-DB51T RAM Replacement: 4 단계, 이미지 2/2
    • Remove the tri-point screws that secure the battery to the casing.
    • All screws securing the battery in place are .5 cm tri-point screws.
  5. Asus V500CA-DB51T RAM Replacement: 5 단계, 이미지 1/3 Asus V500CA-DB51T RAM Replacement: 5 단계, 이미지 2/3 Asus V500CA-DB51T RAM Replacement: 5 단계, 이미지 3/3
    • Use the opening tool to pop up the battery away from the casing.
  6. Asus V500CA-DB51T RAM Replacement, RAM: 6 단계, 이미지 1/2 Asus V500CA-DB51T RAM Replacement, RAM: 6 단계, 이미지 2/2
    • Pull the two RAM retaining arms away from the center of the RAM chip.
    • The RAM will pop up by a few millimeters.
    • Pull the RAM stick out of its socket.
결론
Galen P Garofalo
회원 가입일: 10/17/17
670 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team S6-G2, Rockett Fall 2017 UMass Dartmouth, Team S6-G2, Rockett Fall 2017 회원
UMASSD-ROCKETT-F17S6G2
3 회원들
안내서 6개 작성하였습니다
댓글 2개
"Step 6: Using a pair of tweezers, gently pull the RAM out of its socket." Uhhhh, NO!!!! This is horrible advice. Most tweezers are made of metal, rigid and have hard angles. #1, never touch anything metal to ANYTHING inside of a computer. You could send an electrostatic surge from your body through the tweezers to the object you're going to touch. THIS IS A GINORMOUS NO-NO!. Unless the tweezers are made of plastic or wood, you should never consider this, EVER!
The correct way to do this is to ground yourself with a grounding strap. If you don't have one of those, touch a piece of metal that may be grounded. If you don't have that, touch a computer case with both hands to drain your static charge, since computers are grounded. Then, WITH YOUR >>>HANDS ONLY<<<, remove the stick of memory.
I've been building computers for 20+ years. NEVER HAVE I EVER heard someone say use tweezers to touch any internal components. That's just a recipe for nuking your computer. DONT DO IT!
Jeff Oculush - 답글
Hi @jeffoculush, thank you for pointing that out! We've made an update to the guide to reflect proper instructions and also deleted the photo. Thanks again!
Sarah Westberg -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 405
