주요 콘텐츠로 건너뛰기
Asus V500CA-DB51T Screen Replacement
필요한 것
  1. Asus V500CA-DB51T Screen Replacement, Battery: 1 단계, 이미지 1/2 Asus V500CA-DB51T Screen Replacement, Battery: 1 단계, 이미지 2/2
    • The top left and right corners have .7 cm screws.
    • The two top-middle and four bottom are .4 cm screws.
    • The middle left and right are .8 cm screws.
    • Remove the screws using the Phillips #00 screwdriver.
  2. Asus V500CA-DB51T Screen Replacement: 2 단계, 이미지 1/2 Asus V500CA-DB51T Screen Replacement: 2 단계, 이미지 2/2
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. Asus V500CA-DB51T Screen Replacement: 3 단계, 이미지 1/1
    • Use the flat end of the blue plastic opening tool to lift the battery connector up out of its socket on the motherboard.
  4. Asus V500CA-DB51T Screen Replacement: 4 단계, 이미지 1/2 Asus V500CA-DB51T Screen Replacement: 4 단계, 이미지 2/2
    • Remove the tri-point screws that secure the battery to the casing.
    • All screws securing the battery in place are .5 cm tri-point screws.
  5. Asus V500CA-DB51T Screen Replacement: 5 단계, 이미지 1/3 Asus V500CA-DB51T Screen Replacement: 5 단계, 이미지 2/3 Asus V500CA-DB51T Screen Replacement: 5 단계, 이미지 3/3
    • Use the opening tool to pop up the battery away from the casing.
  6. Asus V500CA-DB51T Screen Replacement, WiFi Card: 6 단계, 이미지 1/2 Asus V500CA-DB51T Screen Replacement, WiFi Card: 6 단계, 이미지 2/2
    • Locate the section of the device that houses the WiFi Card.
    • This should be a white, square-shaped object located just above the left end of the battery.
  7. Asus V500CA-DB51T Screen Replacement: 7 단계, 이미지 1/2 Asus V500CA-DB51T Screen Replacement: 7 단계, 이미지 2/2
    • Disconnect the black and white wires that are connected to the WiFi card by gently pulling them upward with a pair of tweezers.
    • Using the tweezers, gently pull the WiFi card out away from yourself.
    • If you try pulling up you could cause damage, so be sure to slowly and gently pull the card away from yourself.
  8. Asus V500CA-DB51T Screen Replacement, Screen: 8 단계, 이미지 1/3 Asus V500CA-DB51T Screen Replacement, Screen: 8 단계, 이미지 2/3 Asus V500CA-DB51T Screen Replacement, Screen: 8 단계, 이미지 3/3
    • Gently remove the ribbon cable using tweezers.
    • Using the Phillips #00 screwdriver remove the six .4 cm screws from the screen brackets.
  9. Asus V500CA-DB51T Screen Replacement: 9 단계, 이미지 1/3 Asus V500CA-DB51T Screen Replacement: 9 단계, 이미지 2/3 Asus V500CA-DB51T Screen Replacement: 9 단계, 이미지 3/3
    • Slowly lift up on the main case of the laptop.
    • Gently pull the laptop from the screen when it is perpendicular with the screen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Galen P Garofalo
회원 가입일: 10/17/17
670 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team S6-G2, Rockett Fall 2017 UMass Dartmouth, Team S6-G2, Rockett Fall 2017 회원
UMASSD-ROCKETT-F17S6G2
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 6
전체 시간: 618
