소개
In this guide, you will learn how to replace the speakers in the Asus V500CA-DB51T. This guide was made to help with replacing broken or defective speakers, and is a moderately challenging repair.
필요한 것
Remove the following ten screws securing the lower case to the upper case:
The top left and right corners have .7 cm screws.
The two top-middle and four bottom are .4 cm screws.
The middle left and right are .8 cm screws.
Remove the screws using the Phillips #00 screwdriver.
Remove the following screws securing the battery connector board to the logic board:
The red screws are size 2.3 cm T6 Torx
The orange screws are size 2.4 cm T6 Torx
Using the tweezers gently remove the ribbon cable.
Also using the tweezers pry off the metallic tape on both sides of the mouse pad.
Remove the mouse pad from the main assembly.
