주요 콘텐츠로 건너뛰기
Asus V500CA-DB51T Speaker Replacement
필요한 것
  1. Asus V500CA-DB51T Speaker Replacement, Battery: 1 단계, 이미지 1/2 Asus V500CA-DB51T Speaker Replacement, Battery: 1 단계, 이미지 2/2
    • The top left and right corners have .7 cm screws.
    • The two top-middle and four bottom are .4 cm screws.
    • The middle left and right are .8 cm screws.
    • Remove the screws using the Phillips #00 screwdriver.
  2. Asus V500CA-DB51T Speaker Replacement: 2 단계, 이미지 1/2 Asus V500CA-DB51T Speaker Replacement: 2 단계, 이미지 2/2
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. Asus V500CA-DB51T Speaker Replacement: 3 단계, 이미지 1/1
    • Use the flat end of the blue plastic opening tool to lift the battery connector up out of its socket on the motherboard.
  4. Asus V500CA-DB51T Speaker Replacement: 4 단계, 이미지 1/2 Asus V500CA-DB51T Speaker Replacement: 4 단계, 이미지 2/2
    • Remove the tri-point screws that secure the battery to the casing.
    • All screws securing the battery in place are .5 cm tri-point screws.
  5. Asus V500CA-DB51T Speaker Replacement: 5 단계, 이미지 1/3 Asus V500CA-DB51T Speaker Replacement: 5 단계, 이미지 2/3 Asus V500CA-DB51T Speaker Replacement: 5 단계, 이미지 3/3
    • Use the opening tool to pop up the battery away from the casing.
  6. Asus V500CA-DB51T Speaker Replacement, Hard Drive: 6 단계, 이미지 1/3 Asus V500CA-DB51T Speaker Replacement, Hard Drive: 6 단계, 이미지 2/3 Asus V500CA-DB51T Speaker Replacement, Hard Drive: 6 단계, 이미지 3/3
    • Remove the following screws securing the battery connector board to the logic board:
    • The red screws are size 2.3 cm T6 Torx
    • The orange screws are size 2.4 cm T6 Torx
  7. Asus V500CA-DB51T Speaker Replacement: 7 단계, 이미지 1/2 Asus V500CA-DB51T Speaker Replacement: 7 단계, 이미지 2/2
    • Remove the SSD (Solid State Drive) assembly from the upper case.
  8. Asus V500CA-DB51T Speaker Replacement, Speaker: 8 단계, 이미지 1/3 Asus V500CA-DB51T Speaker Replacement, Speaker: 8 단계, 이미지 2/3 Asus V500CA-DB51T Speaker Replacement, Speaker: 8 단계, 이미지 3/3
    • Using the tweezers gently remove the ribbon cable.
    • Also using the tweezers pry off the metallic tape on both sides of the mouse pad.
    • Remove the mouse pad from the main assembly.
  9. Asus V500CA-DB51T Speaker Replacement: 9 단계, 이미지 1/3 Asus V500CA-DB51T Speaker Replacement: 9 단계, 이미지 2/3 Asus V500CA-DB51T Speaker Replacement: 9 단계, 이미지 3/3
    • Remove the ribbon cable for the LED lights.
    • Remove the speaker wire cable from the main board.
    • Slowly pull the speaker wire from the assembly.
  10. Asus V500CA-DB51T Speaker Replacement: 10 단계, 이미지 1/3 Asus V500CA-DB51T Speaker Replacement: 10 단계, 이미지 2/3 Asus V500CA-DB51T Speaker Replacement: 10 단계, 이미지 3/3
    • Gently pry the left speaker from the assembly.
    • Then pry the right speaker from the assembly.
결론
Galen P Garofalo
회원 가입일: 10/17/17
670 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team S6-G2, Rockett Fall 2017 UMass Dartmouth, Team S6-G2, Rockett Fall 2017 회원
UMASSD-ROCKETT-F17S6G2
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 138
