메인 콘텐츠로 스킵하기
부품
지정된 부품이 없습니다.
  1. Flip the computer over so that it is upside down. Slide both latches away from each other (towards the outside).
    • Flip the computer over so that it is upside down.
    • Slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not shown in the photograph.
  2. Remove highlighted screws, pry open case at highlighted spot. Remove highlighted screws, pry open case at highlighted spot.
    • Remove highlighted screws, pry open case at highlighted spot.
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. There are red, yellow, and black set of wires going to a white connector. Grab the three cables and pull straight up, away from the computer. Make sure not to pull wires from connector. White connector should pop off with very little force.
    • There are red, yellow, and black set of wires going to a white connector. Grab the three cables and pull straight up, away from the computer.
    • Make sure not to pull wires from connector. White connector should pop off with very little force.
  5. Remove screws highlighted. Remove screws highlighted.
    • Remove screws highlighted.
  6. Fan should come up very easily. Grab the set of wires that you disconnected earlier and pull straight up. In our pictured fan, there are a few pieces missing.
    • Fan should come up very easily. Grab the set of wires that you disconnected earlier and pull straight up.
    • In our pictured fan, there are a few pieces missing.
  7. Use a cotton swab to remove dust. Also you can use compressed air, blow air from the inside out to clear dust from vent, or heat sink. Use a cotton swab to remove dust. Also you can use compressed air, blow air from the inside out to clear dust from vent, or heat sink.
    • Use a cotton swab to remove dust. Also you can use compressed air, blow air from the inside out to clear dust from vent, or heat sink.
결론
Jong Park
회원 가입일: 2010년 06월 24일
114 평판
안내서 5개 작성하였습니다
Cal Poly, Team 2-9, Johann Summer 2010 Cal Poly, Team 2-9, Johann Summer 2010 회원
CPSU-JOHANN-R10S2G9
5 회원들
안내서 10개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 4,801
