주요 콘텐츠로 건너뛰기
Asus V6800V Hard Drive Replacement
필요한 것
  1. Asus V6800V Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/2 Asus V6800V Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/2
    • Remove the two screws using a Phillips #0 screwdriver.
  2. Asus V6800V Hard Drive Replacement: 2 단계, 이미지 1/2 Asus V6800V Hard Drive Replacement: 2 단계, 이미지 2/2
    • Pry open the case using an iFixit opening tool.
    • Actual hard drive is not shown in the second image.
  3. Asus V6800V Hard Drive Replacement: 3 단계, 이미지 1/2 Asus V6800V Hard Drive Replacement: 3 단계, 이미지 2/2
    • The highlighted area is where your hard drive would be. Slide it out away from its slot and pull it gently to remove.
    • Second image shows what it should look like once you remove the hard drive.
결론
Jong Park
회원 가입일: 06/24/10
114 평판
안내서 5개 작성하였습니다
Cal Poly, Team 2-9, Johann Summer 2010 Cal Poly, Team 2-9, Johann Summer 2010 회원
CPSU-JOHANN-R10S2G9
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 2,955
