소개
Removing the keyboard is a useful way to clean it, or it can be replaced if broken.
The keyboard needs to be removed if you wish to remove the top part of the case for further maintenance of the computer.
부품
부품은 필요하지 않습니다.
  1. First, the screws on the bottom need to be removed first.
    • First, the screws on the bottom need to be removed first.
    댓글 쓰기
  2. There are 4 small tabs holding the keyboard in place. These are located above the F1, F5, F10, and Ins keys. pic 69
    • There are 4 small tabs holding the keyboard in place. These are located above the F1, F5, F10, and Ins keys. pic 69
    댓글 쓰기
    • Starting on one side, use a finger or small tool to press the tab into the chassis of the computer. The edge of the keyboard will elevate. 72, 73
    댓글 쓰기
    • Continue down the keyboard. The keyboard will be noticeably elevated. 82, 83
    댓글 쓰기
    • Once all of the tabs are indented, the keyboard will eject itself, remaining elevated. 388
    댓글 쓰기
    • Partially remove the keyboard by sliding the elevated keyboard towards the screen. Don't remove it all of the way, as we need to remove it's cable first. 389
    댓글 쓰기
    • To remove the cable holding the keyboard in, flip the keyboard upside down. 391 Using your forefinger and thumb, pinch both sides of the cable and pull away from the connector. 396, 401
    • You now have the keyboard separated from the computer. If you wish to clean it, you can use compressed air to blow the dirt out.
    댓글 쓰기
결론
다른 6명이 해당 안내서를 완성하였습니다.
Brian Tubb
회원 가입일: 2010년 06월 24일
272 평판
안내서 3개 작성하였습니다
Cal Poly, Team 2-9, Johann Summer 2010 Cal Poly, Team 2-9, Johann Summer 2010 회원
CPSU-JOHANN-R10S2G9
5 회원들
안내서 11개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 2,186
