주요 콘텐츠로 건너뛰기
Asus V6800V RAM Replacement
필요한 것
  1. Asus V6800V RAM Replacement, Battery: 1 단계, 이미지 1/2 Asus V6800V RAM Replacement, Battery: 1 단계, 이미지 2/2
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V RAM Replacement, RAM: 2 단계, 이미지 1/1
    • On the back panel unscrew highlighted screws and carefully put them to the side as not to lose them.
  3. Asus V6800V RAM Replacement: 3 단계, 이미지 1/1
    • Locate the RAM chip and the two metal tabs holding it in place.
  4. Asus V6800V RAM Replacement: 4 단계, 이미지 1/1
    • Carefully use your thumbs to push out the metal tabs and the RAM should spring up.
  5. Asus V6800V RAM Replacement: 5 단계, 이미지 1/1
    • After the ram has sprung up, carefully grab the edges with your fingers and gently pull straight out.
  6. Asus V6800V RAM Replacement: 6 단계, 이미지 1/1
    • After you have gotten either more RAM or replacement RAM line up the pins and slot (highlighted red) in the RAM card with the pin on the computer.
    • Carefully insert the new ram in at the same angle that you removed it at.
    • The other side of the RAM slot is a place for more RAM if you want to put more in.
결론
Connor
회원 가입일: 06/24/10
34 평판
안내서 1개 작성함
Cal Poly, Team 2-9, Johann Summer 2010 Cal Poly, Team 2-9, Johann Summer 2010 회원
CPSU-JOHANN-R10S2G9
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 3,378
