주요 콘텐츠로 건너뛰기
Asus V6800V Wireless Card Replacement
필요한 것
  1. Asus V6800V Wireless Card Replacement, Battery: 1 단계, 이미지 1/2 Asus V6800V Wireless Card Replacement, Battery: 1 단계, 이미지 2/2
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V Wireless Card Replacement, Wireless Card: 2 단계, 이미지 1/2 Asus V6800V Wireless Card Replacement, Wireless Card: 2 단계, 이미지 2/2
    • Remove the six screws highlighted on the picture.
    • Once the screws are removed, pry open the panel with the pry tool.
    • It should now look like this.
  3. Asus V6800V Wireless Card Replacement: 3 단계, 이미지 1/2 Asus V6800V Wireless Card Replacement: 3 단계, 이미지 2/2
    • After removing that panel, locate the screw on the right as highlighted.
    • Remove that screw.
    • Pry open the side panel with the small prying tool as shown.
    • That panel should pop off and the wireless card will now be easily visible.
  4. Asus V6800V Wireless Card Replacement: 4 단계, 이미지 1/1
    • Place the small prying tool underneath the gold connector and gently apply pressure straight up until it pops off.
    • Repeat for the other one.
    • Place the gold connectors aside.
  5. Asus V6800V Wireless Card Replacement: 5 단계, 이미지 1/3 Asus V6800V Wireless Card Replacement: 5 단계, 이미지 2/3 Asus V6800V Wireless Card Replacement: 5 단계, 이미지 3/3
    • Locate the tabs that are holding the wireless card in place. These are highlighted in picture.
    • Place one finger on each tab and press each to the side away from the wireless card as shown.
    • The wireless card should pop up as shown. Pull up more with fingers to get more clearance.
  6. Asus V6800V Wireless Card Replacement: 6 단계, 이미지 1/2 Asus V6800V Wireless Card Replacement: 6 단계, 이미지 2/2
    • To remove the wireless card, pull the card directly out.
    • It should come out with just a little bit of pressure.
    • It should look as shown when removed.
결론
Steven
회원 가입일: 06/24/10
32 평판
안내서 2개 작성하였습니다
Cal Poly, Team 2-9, Johann Summer 2010 Cal Poly, Team 2-9, Johann Summer 2010 회원
CPSU-JOHANN-R10S2G9
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 3,875
