소개
If you need a new battery on your Asus F412DA laptop here is a guide on how to do it.
필요한 것
이 단계에 사용된 도구:Anti-Static Wrist Strap$7.95
Start by removing the marked screws
Remove the four 6mm screws
Remove the two 8mm screws
Remove the four 9mm screws
Using a opening tool, pry and lift at the edge of the bottom until you feel it open.
Using a fingernail or spudger move back the retaining clip holding the battery connector in place.
Put a spudger under the battery connector and twist, the connector should lift off.
To reassemble your device, insert the new battery and follow these instructions in reverse order.
다른 3명이 해당 안내서를 완성하였습니다.
