주요 콘텐츠로 건너뛰기
Asus VivoBook 14" F412DA Battery Replacement
필요한 것
  1. Asus VivoBook 14" F412DA Battery Replacement, Remove the screws: 1 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
    • Start by removing the marked screws
    • Remove the four 6mm screws
    • Remove the two 8mm screws
    • Remove the four 9mm screws
    • These screws are different lengths, remember which order you removed them. Putting the wrong size screw in the wrong hole can cause damage.
    • The center screw is covered by a sticker that must be removed.
    • It is recommended to wear an anti-static wrist strap for this procedure.
    • Charged Lithium-ion batteries can explode if damaged or punctured, reduce the risk of an explosion by discharging your battery completely before removing.
  2. Asus VivoBook 14" F412DA Battery Replacement, Remove the bottom: 2 단계, 이미지 1/3 Asus VivoBook 14" F412DA Battery Replacement, Remove the bottom: 2 단계, 이미지 2/3 Asus VivoBook 14" F412DA Battery Replacement, Remove the bottom: 2 단계, 이미지 3/3
    • Using a opening tool, pry and lift at the edge of the bottom until you feel it open.
  3. Asus VivoBook 14" F412DA Battery Replacement, Release battery connector: 3 단계, 이미지 1/3 Asus VivoBook 14" F412DA Battery Replacement, Release battery connector: 3 단계, 이미지 2/3 Asus VivoBook 14" F412DA Battery Replacement, Release battery connector: 3 단계, 이미지 3/3
    • Using a fingernail or spudger move back the retaining clip holding the battery connector in place.
    • Be gentle releasing the connector, it's very fragile.
  4. Asus VivoBook 14" F412DA Battery Replacement, Disconnect the battery: 4 단계, 이미지 1/3 Asus VivoBook 14" F412DA Battery Replacement, Disconnect the battery: 4 단계, 이미지 2/3 Asus VivoBook 14" F412DA Battery Replacement, Disconnect the battery: 4 단계, 이미지 3/3
    • Put a spudger under the battery connector and twist, the connector should lift off.
    • Caution: Use a plastic tool, to avoid risk of puncturing the battery. A punctured battery may leak dangerous chemicals or catch fire.
  5. Asus VivoBook 14" F412DA Battery Replacement, Unscrew the battery: 5 단계, 이미지 1/1
    • Remove the two 5mm screws.
    • Remove the 4mm screw.
    • These screws are different lengths so take extra care to track where each one come from.
  6. Asus VivoBook 14" F412DA Battery Replacement, Remove the battery: 6 단계, 이미지 1/1
    • Carefully lift the old battery out of the computer.
    • The battery should be easy to remove. If the battery does not come out easily, double check that all screws are removed.
결론
To reassemble your device, insert the new battery and follow these instructions in reverse order.
다른 3명이 해당 안내서를 완성하였습니다.
Jonathan D Banwart
회원 가입일: 04/19/21
592 평판
안내서 2개 작성하였습니다
댓글 한 개
Can I get a link of the RAM 🙏
Mrs burrito - 답글
댓글 쓰기
조회 통계:
24 시간 전: 24
7일 전: 112
30일 전: 491
전체 시간: 8,607
