주요 콘텐츠로 건너뛰기
Asus VivoBook E203MA-TBCL432B Back Panel Replacement
필요한 것
  1. Asus VivoBook E203MA-TBCL432B Back Panel Replacement, Back Panel: 1 단계, 이미지 1/1
    • Position the laptop so that the bottom panel is facing upwards, the hinge is away from you, and the ASUS logo is against the table.
    • It will be easier to replace the battery if the laptop is closed.
  2. Asus VivoBook E203MA-TBCL432B Back Panel Replacement: 2 단계, 이미지 1/3 Asus VivoBook E203MA-TBCL432B Back Panel Replacement: 2 단계, 이미지 2/3 Asus VivoBook E203MA-TBCL432B Back Panel Replacement: 2 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to remove the eight 5 mm screws on the back panel.
    • Remove the two 7 mm Phillips #0 screws.
    • The 8 screws marked in red are all of the same length, 5 mm, and should not be interchanged with the two longer 7 mm screws marked in orange.
  3. Asus VivoBook E203MA-TBCL432B Back Panel Replacement: 3 단계, 이미지 1/3 Asus VivoBook E203MA-TBCL432B Back Panel Replacement: 3 단계, 이미지 2/3 Asus VivoBook E203MA-TBCL432B Back Panel Replacement: 3 단계, 이미지 3/3
    • Insert the iFixit opening tool in between the back panel and the rest of the laptop.
    • With the iFixit opening tool, lift the panel from the laptop body. Work your way around the device creating separation with the tool.
    • Once there is enough separation between the back panel and the device, gently pull off the back panel with your hands and completely remove it.
    • Make sure to use a plastic tool, not a metal one, so that you don't scratch the panel.
결론
To reassemble your device, follow these instructions in reverse order. The plastic opening tool is not required to reattach the panel. Place the panel in its proper position, then push it firmly down. Do this on all sides of the panel until you hear a click.
다른 2명이 해당 안내서를 완성하였습니다.
Brad
회원 가입일: 03/20/19
539 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S8-G1, Bailey Spring 2019 UMass Dartmouth, Team S8-G1, Bailey Spring 2019 회원
UMASSD-BAILEY-S19S8G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 9
30일 전: 20
전체 시간: 693
