소개
If you find that you need to replace the motherboard on the Asus VivoBook E203MA-TBCL432B, this guide will help you access it. This replacement requires only a standard Phillips #0 screwdriver and a plastic opening tool. The screwdriver is used to remove the screws on the bottom panel of the laptop and the screws connecting the battery and motherboard to the laptop. This is a simple replacement and should not require any additional knowledge or information.
필요한 것
Position the laptop so that the bottom panel is facing upwards, the hinge is away from you, and the ASUS logo is against the table.
Insert the iFixit opening tool in between the back panel and the rest of the laptop.
With the iFixit opening tool, lift the panel from the laptop body. Work your way around the device creating separation with the tool.
Once there is enough separation between the back panel and the device, gently pull off the back panel with your hands and completely remove it.
Now that the back panel is removed you can clearly see the battery and all of its connectors.
Begin by removing the silver ribbon cable along the back of the battery.
To disconnect it from the motherboard, lift the black tab on the Zero Insertion Force (ZIF) connector up and pull the cable away using the blue tab.
Disconnect the ribbon cable from the left side in the same way.
Disconnect the small black and red bundled cable by lifting it directly up from the connector on the motherboard.
다른 7명이 해당 안내서를 완성하였습니다.
