주요 콘텐츠로 건너뛰기
Asus VivoBook E203MA-TBCL432B Power Button Replacement
필요한 것
  1. Asus VivoBook E203MA-TBCL432B Power Button Replacement, Back Panel: 1 단계, 이미지 1/1
    • Position the laptop so that the bottom panel is facing upwards, the hinge is away from you, and the ASUS logo is against the table.
    • It will be easier to replace the battery if the laptop is closed.
  2. Asus VivoBook E203MA-TBCL432B Power Button Replacement: 2 단계, 이미지 1/3 Asus VivoBook E203MA-TBCL432B Power Button Replacement: 2 단계, 이미지 2/3 Asus VivoBook E203MA-TBCL432B Power Button Replacement: 2 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to remove the eight 5 mm screws on the back panel.
    • Remove the two 7 mm Phillips #0 screws.
    • The 8 screws marked in red are all of the same length, 5 mm, and should not be interchanged with the two longer 7 mm screws marked in orange.
  3. Asus VivoBook E203MA-TBCL432B Power Button Replacement: 3 단계, 이미지 1/3 Asus VivoBook E203MA-TBCL432B Power Button Replacement: 3 단계, 이미지 2/3 Asus VivoBook E203MA-TBCL432B Power Button Replacement: 3 단계, 이미지 3/3
    • Insert the iFixit opening tool in between the back panel and the rest of the laptop.
    • With the iFixit opening tool, lift the panel from the laptop body. Work your way around the device creating separation with the tool.
    • Once there is enough separation between the back panel and the device, gently pull off the back panel with your hands and completely remove it.
    • Make sure to use a plastic tool, not a metal one, so that you don't scratch the panel.
  4. Asus VivoBook E203MA-TBCL432B Power Button Replacement, Power Button: 4 단계, 이미지 1/2 Asus VivoBook E203MA-TBCL432B Power Button Replacement, Power Button: 4 단계, 이미지 2/2
    • Remove the single connector by first pulling back the white tab and then pulling the connector out with the blue tab.
  5. Asus VivoBook E203MA-TBCL432B Power Button Replacement: 5 단계, 이미지 1/2 Asus VivoBook E203MA-TBCL432B Power Button Replacement: 5 단계, 이미지 2/2
    • Remove the single 2 mm screw with a Phillips #0 screwdriver.
  6. Asus VivoBook E203MA-TBCL432B Power Button Replacement: 6 단계, 이미지 1/1
    • Now that the power button component is free, lift it up and out of the laptop.
결론
Jacob Aubertine
회원 가입일: 03/21/19
470 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S8-G1, Bailey Spring 2019 UMass Dartmouth, Team S8-G1, Bailey Spring 2019 회원
UMASSD-BAILEY-S19S8G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 4
30일 전: 17
전체 시간: 898
