주요 콘텐츠로 건너뛰기
Asus VivoBook E203MA-TBCL432B Speaker Replacement
필요한 것
  1. Asus VivoBook E203MA-TBCL432B Speaker Replacement, Back Panel: 1 단계, 이미지 1/1
    • Position the laptop so that the bottom panel is facing upwards, the hinge is away from you, and the ASUS logo is against the table.
    • It will be easier to replace the battery if the laptop is closed.
  2. Asus VivoBook E203MA-TBCL432B Speaker Replacement: 2 단계, 이미지 1/3 Asus VivoBook E203MA-TBCL432B Speaker Replacement: 2 단계, 이미지 2/3 Asus VivoBook E203MA-TBCL432B Speaker Replacement: 2 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to remove the eight 5 mm screws on the back panel.
    • Remove the two 7 mm Phillips #0 screws.
    • The 8 screws marked in red are all of the same length, 5 mm, and should not be interchanged with the two longer 7 mm screws marked in orange.
  3. Asus VivoBook E203MA-TBCL432B Speaker Replacement: 3 단계, 이미지 1/3 Asus VivoBook E203MA-TBCL432B Speaker Replacement: 3 단계, 이미지 2/3 Asus VivoBook E203MA-TBCL432B Speaker Replacement: 3 단계, 이미지 3/3
    • Insert the iFixit opening tool in between the back panel and the rest of the laptop.
    • With the iFixit opening tool, lift the panel from the laptop body. Work your way around the device creating separation with the tool.
    • Once there is enough separation between the back panel and the device, gently pull off the back panel with your hands and completely remove it.
    • Make sure to use a plastic tool, not a metal one, so that you don't scratch the panel.
  4. Asus VivoBook E203MA-TBCL432B Speaker Replacement, Speaker: 4 단계, 이미지 1/3 Asus VivoBook E203MA-TBCL432B Speaker Replacement, Speaker: 4 단계, 이미지 2/3 Asus VivoBook E203MA-TBCL432B Speaker Replacement, Speaker: 4 단계, 이미지 3/3
    • Using the iFixit opening tool, pry up and remove the battery connector from the motherboard.
    • Using the iFixit opening tool again, carefully wedge the tool under a corner of the speaker connector on the motherboard that is connected by three wires (colored red, black, and white).
    • Slowly pry the connector up without damaging the motherboard.
  5. Asus VivoBook E203MA-TBCL432B Speaker Replacement: 5 단계, 이미지 1/3 Asus VivoBook E203MA-TBCL432B Speaker Replacement: 5 단계, 이미지 2/3 Asus VivoBook E203MA-TBCL432B Speaker Replacement: 5 단계, 이미지 3/3
    • Using a Phillips #00 screwdriver, remove the four 2.0 mm screws near the edge opposite of the hinge.
    • Insert the iFixit opening tool underneath the red and black wire and remove the wire from the small clasps.
  6. Asus VivoBook E203MA-TBCL432B Speaker Replacement: 6 단계, 이미지 1/2 Asus VivoBook E203MA-TBCL432B Speaker Replacement: 6 단계, 이미지 2/2
    • Insert the iFixit opening tool underneath the speaker on the right side. Gently pry the speaker up to remove.
    • Repeat the step above for the opposite speaker. Then, carefully set both speakers off to the side.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Khadijah Sulail
회원 가입일: 11/16/19
415 평판
안내서 3개 작성하였습니다
IUPUI, Team S3-G3, Wilson Fall 2019 IUPUI, Team S3-G3, Wilson Fall 2019 회원
IUPUI-WILSON-F19S3G3
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 357
