주요 콘텐츠로 건너뛰기
Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement
필요한 것
  1. Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement, Hard Disk Drive: 1 단계, 이미지 1/1
    • Disconnect laptop from the power supply.
  2. Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the ten 6.4 mm screws from the bottom cover.
  3. Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement: 3 단계, 이미지 1/2 Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement: 3 단계, 이미지 2/2
    • Use a metal or nylon spudger to pry open the back cover on all sides.
    • Remove the back cover to access the inside where the hard disk drive is located.
  4. Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement: 4 단계, 이미지 1/1
    • Locate the hard-drive.
    • Disconnect the hard disk drive from its connectors, and remove the drive.
    • Place the new HDD in the same location and orientation.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Justin Martel
회원 가입일: 03/22/22
159 평판
안내서 1개 작성함
UMass Dartmouth, Team 7-2, Sinclaire Spring 2022 UMass Dartmouth, Team 7-2, Sinclaire Spring 2022 회원
UMASSD-SINCLAIRE-S22S7G2
5 회원들
안내서 2개 작성하였습니다
댓글 한 개
Hey, do you by any chance have the reference for the battery in the Asus TP410U ? Thank you!
Matt JBOM - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 14
30일 전: 41
전체 시간: 1,424
